xm radio antenna too short!!!
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Redfisher, Jan 21, 2012.
  1. Redfisher
    Redfisher Bobtail Member
    14
    6
    Aug 16, 2011
    Land O' Lakes FL
    So I tried to mount my satalite radio antenna on the back of my truck and the dang cord is too short to reach the radio. Can I splice the cord??? Maybe a cb tech at a truck stop could do it??? I know they make extension cords but I don't get home very often and I haven't seen any at truckstops.
    The basic antenna on the dash is not cutting it. It seems to be fuzzing out more than it works.
    Help???
  3. Redfisher
    14
    6
    Aug 16, 2011
    Land O' Lakes FL
    BTW...I drive a T700 KW. So there are few options for mounting other than behind the cab.
  4. Beer Runner
    Beer Runner Medium Load Member
    544
    227
    Nov 2, 2010
    Canada
    Now why would you do that? Just put it on the mirror like everyone else and it will work fine.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Try calling them.
    http://www.digitalantenna.com/satelliteradioaccessories.html
    If you just do a search on XM Radio Extension cables you will find a few. It will depend on the two end connectors. So, it would good to call the folks at the above link.
    Thanks,
    Mark
  6. tech10171968
    tech10171968 Medium Load Member
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    Not an option on this truck model. Note the "Gullwing" mirrors in the attached picture.
  7. Beer Runner
    544
    227
    Nov 2, 2010
    Canada
    Good point. But if you get the hood mirror you can put the antenna on that. I have seen others do that.
  8. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    buy one of the metal plates made to attach the magnet antennae to, remove one of your cb antennae place the place and screw the antenae back down it holds the plate perfectly. any truckstop has them 10.99 at most places
  9. tech10171968
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    I've seen that, too. Don't know how his tractor's spec'd, though. I drive a Cascadia and that model has the exact same problem: the "Aero" design doesn't leave a lot of options as far as mounting anything.
    I was able to get around it by purchasing a couple of "bird perch" mounts made especially for that truck. You simply back out one of the screws holding the mirror and replace it with the mount. I wonder if anyone makes something like that for KW?
  10. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    I have a T2000, but have seen other drivers doing what I have done.
    Same mirrors.
    I purchased the antenna that is about 1" square x 1/2" tall. used velcro to attach to the top of my mirror. Opened up mirror (six screws) ran wire thru mirror, then zip tied to arm, ran in door.
    Always works fine, no permanent attachment to truck, very un noticeable.
  11. Roehlworld
    Roehlworld Bobtail Member
    31
    15
    Sep 7, 2011
    Southeast Wisconsin
    i ran my stock cord out the door, above the fuel tank, behind my headache rack, and it stuck to where my quallcomm satellite sits, with about 3 extra feet of cord.
