XM radio for Cascadia fix
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Palazon, Nov 19, 2012.
  1. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    Finally found a fix for mounting an XM radio antenna on a Cascadia. I have the older "wand or stick" style antenna that used to mount on the mirror. I found a small bracket at truck stop that is for mounting magnetic antennas. It has a hole to attach it with your CB antenna. I just drillled 2 holes, bent it at 90 degrees, and attached the xm to it, mounting it at the CB antenna on the drivers side. Great reception.
    This should work on most of the newer aerodynamic trucks. Will post a pic as soon as I figure out how and have coverage. :biggrin_255:
