Xm Radio noise
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Cab Lizzard, Nov 19, 2012.
  1. Cab Lizzard
    Cab Lizzard Light Load Member
    118
    45
    May 16, 2011
    MIA
    Winshield mount in an 02 International Eagle auto trans. Power is through the aux cig lighter.I get a whine that goes louder as the transmission winds up.
    It goes through the stock radio and have tried both the single wire port on the front and the rca jacks on the rear. No whine when I run from i pod to radio receiver with wire on front. Also put a few chokes from Radio Shack on the power wires, no change. Anyone got any reasonable idea ?
  3. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    try moving the antenna wire to different route the one for the satellite it can pickup noise
  4. MsJamie
    MsJamie Road Train Member
    You have a ground loop causing the noise. An isolating cable should do the trick. Do a web search for a Kensington K39203US cable; I like mine so much I have two spares...
  5. Cab Lizzard
    118
    45
    May 16, 2011
    MIA
    Thank-you ...Anybody stock these cables ??
  6. MsJamie
  7. snowwy
    snowwy Road Train Member
    20,544
    13,279
    Jul 6, 2009
    the problem is your aux wires. your pickng up noise from the alternator. not the transmission.
    plug your phone into the aux jack. and play a song or even your mp3 player. listen to the noise. unplug the lighter plug and hear the noise go away.
    you won't hear the noise if you use the fm transmitter built into the satellite radio.
    the problem with the fm transmitter though is a church channel that seems to broadcast everywhere in america. it over rides whatever station you happen to be using. and it's different station where ever your at.
    that's why i stick with the aux port.
