You guys have rear axle weight gauge on your trucks?
Discussion in 'Heartland' started by chp56, Aug 16, 2013.
  1. chp56
    chp56 Light Load Member
    150
    33
    Sep 25, 2011
    Barstow, Ca
    Lotta #### scaling if not
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    yep have 24 guages on my dash
  4. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    it's a 50 buck project that takes less than an hour. (assuming you have air ride, safe assumption considering there are very very few spring ride tractors left out here). there is no reason not to have a suspension gauge in your truck. even for company drivers.
  5. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    Hard to find a truck without the suspension load gauge. If you do find one, good reason to put in an Air-weigh gauge. Converts your pounds of system pressure into actual weight in pounds or kg. Can be within 250 pounds properly calibrated.
  6. Ric Rabbit
    Ric Rabbit Light Load Member
    149
    92
    Oct 5, 2012
    Atlanta metro area GA
    Have found "in excess of 60lbs" does same thing!
    How many trucks these days have an oversized Pyrometer ?
  7. spyder7723
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    62pounds is my magic number for 34k pounds on drives. normal suspension gauge is a lot cheaper and does the same thing
