Ok everybody, lets say money was no object...maybe you hit it big on the lotto and wanted to keep on truckin. What would be your dream truck and why? New or Old, pros & cons. Just wondering what everyone would have if they could....Have fun with this thread and THANKS!
Your dream truck
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TIMEWEASEL, May 12, 2010.
Page 1 of 4
scania r480LB 4x2 mna
engine : dc13 07 480hp 2500nm ~1850lb ft
gearbox grs905r -manual eg651 -pto
cab : cr19N
frame: f800 with 4900mm wheelbase
front axle am740
rear axle : ad1100/1300 or ad1302 ( special order) with r780 diff 3.08 ratio
TIMEWEASEL Thanks this. -
u looken at it through my eyes
allready own it 06 pete 379exhd long wb big cat 18spd flat top sleeper all the bells and whistle's.
When I win the lottery my dream truck will be a brand new star with a 132" sleeper, 625 cat, 3:50 rears, 13 speed od, with all the bells & whistle's. Gotta have a fair amount of lights too. I'll have a matching 50' spread axle trailer with the right amount of lights.
Captain Canuck and TIMEWEASEL Thank this. -
This is probably the most frequent daydream running through my head as I'm running down the road.
I'd have to have it custom built. I hate having equipment that doesn't stand out. Ain't gotta be pretty...just gotta be unique and built for a purpose.
...and you said money was unlimited, right?
I'd have to find a solid B-75 Mack cab with a clean title...I'd want it titled as a mid-1950's to early-1960's truck. Day cab, of course...I don't like going too far from home anymore. I'd update it a little...add air ride to the cab for a little better ride, and it would have a full array of gauges on the dash. I don't need air conditioning...just give me a sliding rear window.
I'd get a Mack Cornerstone chassis to mount the cab...7/16" frame rails. Heck, put an insert in there to double it up, too. The severe duty crossmember package sounds good, too....gotta make it bullet-proof. I'd set it up to be around a 216" wheel base.
I'd get a Mack E9 V8 motor and squeeze it under the hood (may require some body alterations)...turned up to around 600 or 625 HP...and breathing through dual 6" exhaust stacks turned out just above the top of the cab.
Since I probably wouldn't be able to find a 5x4 transmission that could handle that kind of power, I'd have to settle for the T31821.
For the drives, I'd go with the SW582 suspension, but upgrade it to air with Raydan Mfg.'s Air Link. Rears would be 5.02 gears mounted in CRD2021-2031 carriers, with 12R24.5 Michelin XDY 3 tires. Full lockers, of course.
The steer axle would be an FXL23 on multi-leaf shackle springs, with 445/65R22.5 Michelin XFE wide base tires mounted up.
I'd have a Telma Frictionless Braking System mounted in the driveline to help save my brakes....and speaking of brakes, why not go with the Bendix air disc brakes all of the way around?
Roadranger's Central Tire Inflation System is pretty neat, too...so since money is not an issue, I gotta have that...complete with the dash controls to adjust air pressure for load and terrain.
Gotta go heavy-duty on the 5th wheel, too...Fontaine XAWX air-slide bracket, with the X5092 top plate, complete with the KIT-BLK-SLD blocking kit installed.
I'd have dual 100 gallon fuel tanks, with the right side tank split 60 (hydraulic)/40 (fuel). They would be the narrow tanks, so I wouldn't lose any more ground clearance than necessary.
The wet kit would be a little more than I have now...which is already a "custom" install.
Of course then I'd have to add a few side boxes to carry my tools...and maybe a headache rack to hang a few chains on...a sturdy front bumper...and other minor "details".
Yeah, it'd be a friggin' tank. It would be able to go wherever I needed it to go, pull whatever I wanted to pull, and I'd never have to worry about making it back out of any job site. I do end dumps right now...mostly local work...but I wouldn't mind someday getting back out into the woods and hauling sticks again. Maybe get a trailer or two for each...and a low boy to haul my other stuff around...but then I gotta build a bigger shop to keep it all in....
Yup. I'm pretty good at spending money I ain't got in my head.
Give me a Kenworth T660 Studio, ISX600 Cummins w/ 13spd, sun roof, full gauge package, old style windows on the side unlike the new ones, 3.42-355 rears, 22.5 tires, holland air slide 5th wheel, Sears leather seats, power divider, dump valve, auto inflation system for my tires, no roof fairing but turbo wing instead, dual 125 or 150 fuel tanks, alcoa dura-bright wheels, and my color would be purple with matching company logos on my trailer
Trailer: Great Dane 53ft Super Seal with thermo king whisper reefer, spread axle, swing doors, corroguard, puncture guard, and thermoguard, 22.5lp tires, side skirts to epa smart way spec's, 75 gallon reefer tank, matching purple logos to go with truck listed above
KHTIMEWEASEL Thanks this. -
about a 2001 kenworth w900l 62 inch aerocab flat top bunk heavy specs michigan special 235 wheel base c16 625 cat maxed out on horse power and torque 18 speed double over drive 3:90 rears with quad locks 11r 22.5 rubber on rear 385r 60 22.5 rubber on front every lite you could put on it straight 8 in bull hauler stacks wet kit and you said money is no object i mite as well have a brand new set of super train dumps to go with it 28.5 foot lead tandom with a 9 foot spread lift axle a tandom axle dolly with air bags on the fifth wheel to help the dolly lock a 28.5 foot pup with tandom and a 9 foot spread lift with dry tarps smoothsides and every lite you can fit on themand super singles on the lifts that would be my dream ridei woould truck in michigan ohio and indiana
TIMEWEASEL and The Challenger Thank this. -
Mine is easy, I want an air ride day cab with all new insides and good air, cruise tilt, and nice air ride seat. Big Detroit, Jakes, straights, 18spd, all locking 4:33 rear with spring ride. If you can't tell I haul logs, pretty trucks don't stay pretty in the woods. LMAO
I'm already driving my dream truck,.....
The company owns it and they pay for the repairs,....
And my paycheck is always good,.........TIMEWEASEL Thanks this.
Page 1 of 4
