zf 12spd transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kle135, Jan 18, 2014.
  1. kle135
    kle135 Bobtail Member
    5
    I have a Volvo with zf 12spd autoshift. When down shifting from 7 to 6 there is a slight grinding sound.Does anyone have any ideas.Thanks
  3. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    The only thing I can really think of is maybe one of the sliding clutches isn't engaging properly from being worn. Or possibly the electronic shifter messing up
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ouh no, it is worn range synchro, tranny about million miles and range unit would be rebuilt
  5. kle135
    5
    Thanks, Can that be done without disassembling entire trans. Truck has 700,000 . Transmission is a 12spd zf freedomline autoshift
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    on cabovers it is possible to remove range planetary gear from tranny but conventional design truck is other thing. with tranny on truck it is easy to damage wiring of TCU, speed sensors... so I'd drop tranny.
  7. kle135
    5
    Thanks , I will have tranny out to replace clutch. Can syncro be repaired by removing back cover or does it need to go to rebuild shop?
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Not so easy. U have to remove TCU with shift cylinders. Really it is ZF astronic tranny, but with 12 to 24V converter and ZM Tec modul. To remove TCU is easy, but when u install it = be sure shift pistons fit rails, else it may crack when u tigten bolts
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    BTW, all the manuals are available on ZF portal
  10. kle135
    5
