What will be the ratio on this transmission?
I found RMX 10-165A and RMX 10-165C on Google
not sure which one I have,
It is possible to check by truck VIN number or have to crawl under
and find myself?
ZF Meritor RMX 10-16 transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mp4694330, Feb 10, 2013.
find ZF dataplate on top of tranny, usually ZF16 is 1:1 top gear ratio
mp4694330 Thanks this. -
what truck? usually top gear ration is on vehicle dataplate and programmed in engine ECU
2001 Volvo D12
Trans # LB00024232 -
Can You find by VIN #???
http://www.vibratesoftware.com/html...nsmissions/ZF_Meritor_10_speed.htm#RMX10-165A
Maybe this will help.
Good luck. -
M O - Z 12 A - A 1 6
Torque Rating
13 = 1350 lb-ft
14 = 1450 lb-ft
15 = 1550 lb-ft
16 = 1650 lb-ft
ZF-FreedomLine
Ratio
A
Highest Torque
in Top Two Gears
13 = 1350 lb-ft
14 = 1450 lb-ft
15 = 1550 lb-ft
16 = 1650 lb-ft
A = Fully Automated
Platform
O = Overdrive
No Letter = Direct Drive
16
Z = ZF-FreedomLine
12 = 12-Speed
16 = 16-Speed
Really it is European ZF Astronic tranny. The only difference - to fit this TCU on 12 V truck they usew Voltage Doubler -
Both direct drive and Od transmissions were used.
I could be wrong, not an expert, but I think RMX is very different from AS-Tronic. Check this link:
http://www.globaltransmissionsupply...-10-speed-transmissions-c-ratio-overdrive.pdf
Freedomline is AS-Tronic, but OP asked for RMX10-165 -
