Most drivers run with some type of EOBR. My company uses these Qualcomm MCP200 units. Simple touch screen. Well I don't have a stylus so I use a USB keyboard to send messages. My unit has a severe lag. It will hang up and lock for several minutes. I delete all messages that are not needed. My log department says there is nothing that can be done to prevent this lag. Using ctrl alt delete on the keyboard does nothing. Even shutting all power to truck does nothing. I know from a past employer that used the model with the slide out keyboard you could hold a combination of buttons on the unit and make it do a soft reset. Never had a lag issue when I did that. Any suggestions on how to "defrag" this thing to stop this?
Qualcomm
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by jimjam38, Oct 8, 2016.
Page 1 of 3
Clear all the porn out of your history and cookies...always works for me
Call_Me_The_Breeze Thanks this. -
Unhook the batteries for a few minutes...kill ALL power to the entire truck. When you hook them back up EVERYTHING will be forced to reboot. The QualCom should "update" as it's searching for the satellite.
Not sure if there is anything you can do, but your company should be able to fix this.
https://www.yumpu.com/en/document/view/12050263/mcp200-diagnostic-quick-reference-qualcomm -
I always thought it was funny at a huge company we still had to call the manufacturer when we were having problems.
KillingTime Thanks this. -
Find the battery disconnect switch and shut it off for a few minutes. Or u can unplug the power to the unit if u know where the black box is. That usually help.
U could have a defected one and u should get it replace -
I had a similar issue awhile back, I thought I had corrupted software, but the problem turned out to be only a bad power-cord (It can take just so much twisting/curling). PROBLEM SOLVED !
TROOPER to TRUCKER Thanks this.
Mine is the same way. I've always blamed it being an "older" unit with a cheap, slow board hardware. If it's in the process of pushing up log updates, changing log status and updating and saving the duty time, or processing new incoming messages, it can barely do anything else until that task is done.
Page 1 of 3
