‘20 Cascadia, 260k miles…what to expect in the next few years
Discussion in 'Ask An Owner Operator' started by 48Packard, Jul 26, 2023.
  1. 48Packard
    48Packard Ol' Two-stop Shag!
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    Paying off this truck September 8th. Just curious as to what others have experienced repair-wise beyond my current mileage. I’ve got maintenance reserves and will continue to add to them on a per mile basis. But I don’t care for surprises of this nature much and just therefore am sampling the experiences of others, be they OO or company drivers. Thanks as always!
    JoeyJunk Thanks this.
  3. Judge
    88,444
    Mines a 16, 220994BC-B839-4D04-AD62-F11D93CB967A.jpeg Been down a ton of sand/dirt roads in fields, pulled heavy loads up to 117k gross.
    Hadn’t started it since March, Turned key and it fired right up after checking oil and antifreeze.
    Depends on how you service them, When it was parked it was ready to go. I change oil every 12k miles, though lately this one’s been a spare truck.
    Crude Truckin', 48Packard and JoeyJunk Thank this.
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I have a 2021 just the regular maintenance intervals. I had a Def sensor act up(warranty covered). I haven't had any issues. Thank God. I just stay up on the maintenance schedule.
    77fib77, 48Packard and JoeyJunk Thank this.
  5. 48Packard
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    I’ve been faithful on the maintenance. Only pending issue is the camera system that disables the Active Braking and Cruise when it’s out. That’s on the schedule for August.
    Vampire, 77fib77 and JoeyJunk Thank this.
  6. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Soft ware updates are a must.....you will need 12 -16k for one box replacement and 5-7k for EGR cooler. Both above expenses can be cut in more than half if you can do a lot of this your self. And hoses for some reason...
    keep a eye on your anti freeze. Seems like all unprevented maintenance includes antifeeze to one degree or another. I have a 2016. From 680k to 701k miles I couldnt stay out of the shop. Back up and running solid now.
  7. 48Packard
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    I’ve got two years max and maybe another 200k miles to drive before I retire. So if I hit 500k it’ll be a shock as I plan on working a little less, perhaps 80k to 90k miles a year…maybe less.
    Magoo1968, 77fib77, JoeyJunk and 2 others Thank this.
  8. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Nice keep it up
  9. DUNE-T
    DUNE-T Road Train Member
    6,969
    16,909
    May 10, 2015
    Detroit, MI
    My friend owns couple of 2019s. Bought at 400k miles. At 500k miles all sorts of DEF problems start showing up, at 600k one truck had front leaf spring cracked (none available in the USA right now), fuel pump and fuel lines needed to be replaced. Another one had clutch fail (dt12 transmission) almost $10k repair, then something else.
    Basically it seems like after 500k miles they start needing lots of repairs
  10. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    They do. Right as the warranty runs out the repairs come in
    Vampire, 77fib77 and 48Packard Thank this.
  11. RunningAces
    RunningAces Road Train Member
    1,290
    2,561
    Jul 2, 2017
    Woah, it really costs 5-7k for an egr cooler on a Detroit? Cummins isx15 is quite a bit cheaper than that iirc.
    77fib77 Thanks this.
