09 columbia DDV 1500 tops
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by o1reb, Oct 10, 2023.
  1. o1reb
    o1reb Bobtail Member
    49
    21
    Apr 28, 2012
    bedford
    in high range wont go over 1500 1st through 6th no problem new everything turbo, wiring complete engine, harness, boost sensor ,throttle ps, filters no codes, run without dpf no change acts like its has a governor just happened hangin buy a thread
  3. blairandgretchen
    13,667
    74,370
    Dec 9, 2011
    South west Missouri
    Sounds like a parameter in the ECM settings. Plug it in and look at progressive shifting RPM limits would be my loose guess.
    Crude Truckin' Thanks this.
  4. o1reb
    49
    21
    Apr 28, 2012
    bedford
    thank you will try only thing left
    blairandgretchen Thanks this.
  5. blairandgretchen
    13,667
    74,370
    Dec 9, 2011
    South west Missouri
    Normally companies would set up progressive shifting limits for fuel economy, but in reverse to what you described, i.e. -
    Low range 1-5 gear, limited to 1400 RPM,
    High range, no limit or 1600 RPM for example.
    This is done (hopefully along with training) to encourage drivers to conserve fuel by using minimum RPM whilst upshifting.
    If you had the described work completed by a mechanic/shop, I'd look over their shoulder whilst plugged in and set those parameters as you see fit for your operation - they may have flashed or reset your ECM parameters.
  6. Transportauto
    Transportauto Light Load Member
    100
    34
    Apr 10, 2022
    Parameters set incorrectly.
    Second, had a truck years ago that only in 3 & 5 & 8 &10 truck would hang no higher then 1,500 on bumps it would hiccup, found wiring for reverse switch was routed tight on the shift lever caused the wires to rip back and touch . At that time I had no laptops to see this but this truck limited rpm in reverse
