10 or 13 speed?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tug Toy, Oct 16, 2015.
  1. Tug Toy
    Tug Toy Road Train Member
    6,968
    72,909
    Jul 4, 2015
    Corn field
    Is 10th and 13th the same final ratio? I'm putting in a reman trans and wondering if the 13 is worth the extra money?
    Thanks
  3. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
    Depends on the hauling. I prefer more gears over less.
  4. blairandgretchen
    13,377
    71,913
    Dec 9, 2011
    South west Missouri
    Generally yes - 9th and 12th will be 1:1, direct drive, and 10th in a 10speed and 13 in a 13 speed will be 'OD' - but the ratio of overdrive may be different.
    I'm with @lots of character - I prefer more gears, I split 12th/13th a lot, run 55 mph zones in 12th, just depends on what you need.
  5. spyder7723
    spyder7723 Road Train Member
    15,471
    25,070
    Mar 31, 2013
    sarasota, fl
    Unless you mainly pull light loads on flat ground. Get the 13. If you don't, you will wish you had.
  6. Tug Toy
    6,968
    72,909
    Jul 4, 2015
    Corn field
    I haul general FB freight in the Midwest. The truck I drive now has a 13 auto. I do like it but has higher gears than the truck I bought. This is the first 13 I have driven. Looks like about $1600.00 more for the 13 spd plus driveline mods and new shifter. So maybe $2 k in total to upgrade.
  7. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Get the 13, you'll never desire a 10 again....
    KB3MMX Thanks this.
  8. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    13 all the way if it is for you to drive. If it is for a driver I would need to think twice as a 10 speed is pretty hard to tear up.
  9. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Depends on the transmission. There are direct drive transmissions, and overdrive transmissions with variable ratios. The transmission nomenclature can be looked up to determine the final drive ratio of the transmission. Personally, I'd opt for the 13... less gap between gears.
  10. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    I agree with everyone on the 13 over the 10. No one has answered your initial specific question on final ratio, but without knowing the model #'s of the transmissions, we can't. You have to know them, and then you can either look up the ratios yourself, or we can help you. The final ratio of your top gear plays a big part in the personality of your truck as you drive it at cruising speed. Case in point, I bought a brand new truck in 1980, it had a 13 speed with a .86 od ratio (single overdrive). But, it had 10:00-20:00 tires (comparable to todays 11R-22.5 I believe) and a 4.56 final rear end ratio. It was great in the bush and in the mud, but it was a dog on the highway. I always seemed to be pushing it to try and get 60 mph out of it. Looking back now I would have been better off with 4.10 or 3.90 ratio in the rear end. 18 speeds (with the double o/d .73) hadn't been invented yet.
  11. lots of character
    1,031
    1,814
    Aug 12, 2015
    That's what the auxiliary brownies were for @04 LowMax
