12.7 S60 1995 coolant filter bypass question.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blairandgretchen, Oct 29, 2023.
  1. blairandgretchen
    13,659
    74,325
    Dec 9, 2011
    South west Missouri
    Is it necessary to have a coolant filter? The base and lines, shut off valve and filter o-ring has leaked from time to time over the years - I have a blank filter without additive puck.
    Question is - Is it necessary, or can bypass for simplicity?
    It's back to leaking again, just another thing I don't need to mess with OTR.
    Thanks.
    Feedman, Rideandrepair, Oxbow and 2 others Thank this.
  3. wore out
    wore out Numbered Classic
    16,731
    204,745
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    As long as you are running extended life coolant you can do away with it. I finally swapped my B over to extended life and put plugs in where the filter lines come out
  4. pavrom
    pavrom Road Train Member
    3,196
    7,327
    Apr 29, 2012
    NE illinois
    I had trucks with and without. Never been an issue . Dont remember about my cascadia ... I think i dont have one on it
  5. wichris
    wichris Road Train Member
    4,436
    9,082
    Jan 17, 2011
    Just get some test strips. And a bottle of Nalcool if needed.
  6. Rideandrepair
    17,445
    56,610
    Aug 8, 2015
    One more potential leak. If you want to run one, use the need release filter w/additive. Fleets love them. Adds some when the thin layer of sacrificial metal erodes. Change them once a year. Belt and suspenders approach. I had one on this Truck, till the hose blew. Took it off. If I were to use one, I’d put shutoffs at the block/radiatorpipe/waterpump, wherever the hoses are, not just on either side of the filter. That way it can be isolated if a hose leaks.
    blairandgretchen Thanks this.
  7. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    Throw it away LOL
  8. Diesel Dave
    9,293
    29,841
    Jan 20, 2010
    Hesperia, Ca.
    My .02, I would replace the orings on the base and put ball valves instead of using those “faucet” valve set up. That’s exactly what I “did” to my set up. I’ve seen junk inside those coolant filters, I wouldn’t want that junk plug up any tubes inside the radiator core. That’s just my opinion. I’m not no certified mechanic, just a “shade tree” one. :D Those coolant filters are there for a reason.
  9. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    I use elc and a non additive cat filter. It's a convenient place to get coolant samples while the engine is running.
    Rideandrepair Thanks this.
  10. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    run walmart green antifreeze. and no filter for many years
