13 spd Transmission and RPM's. Best cruising gear?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Turbrospeed, Nov 23, 2021.
  1. Turbrospeed
    Turbrospeed Light Load Member
    143
    111
    Apr 23, 2020
    Texas
    Hey guys just wanting to get your opinion.
    Can i cruise in 12th gear for long periods of time?
    Reason i ask is becuase in 13 gear my rpms are only at 1280 at 70 and sometimes with alot of wind i get bad fuel mileage so i have to put 12 n go 60ish so my rpms can be around 1400
    Pamela1990 Thanks this.
  3. xsetra
    xsetra Road Train Member
    4,928
    6,588
    Aug 21, 2011
  4. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    Won’t hurt anything. I re geared from 3:70 to 3:55, and often set the cruise at 62 at 1525 rpm when it’s windy, or heavy.
    jamespmack, Pamela1990 and Turbrospeed Thank this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,193
    6,011
    Aug 26, 2014
    Actually a little easier on the trans. Back box is direct instead of running power through counter shafts.
  6. Turbrospeed
    143
    111
    Apr 23, 2020
    Texas
    If you dont mind me asking, how much did you pay to re-gear?
    And do you just change the gears in one or both diffs?
    blairandgretchen Thanks this.
  7. xsetra
    4,928
    6,588
    Aug 21, 2011
    Differentials gears have to be the same. Change both.
  8. Turbrospeed
    143
    111
    Apr 23, 2020
    Texas
    Very rare that i use the cruise, ive gotten use to my foot on the pedal, cause i stare at my mpgs like a religion
  9. Turbrospeed
    143
    111
    Apr 23, 2020
    Texas
    Thanks for your replys guys... I usually go around 70 and currently getting 8.2 mpg average, but if i go 60-65 in 12 gear i can get 9+
  10. wore out
    wore out Numbered Classic
    14,343
    173,994
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Not quite. On the RTLO transmission back box is an under drive unit. When the button is in direct the back box is turning which is using power flow and making heat. Eaton actually advises against running with the button in direct for long periods though I have never personally seen it anything it hurt. When the button is in overdrive the power flow runs straight through the trans. Which is less rotating mass etc.
    BoxCarKidd, stwik, Roger McG and 5 others Thank this.
  11. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,713
    Nov 7, 2021
    B.C. Canada
    I cruise in 16th or 17th often in my 18 speed. Never be concerned about cruising in top gear, unless it is the right conditions to do so.
