What makes it 13 speeds?
I trained on a 10 speed, and my first job was also on a 10 speed. Now I'm driving a 13 speed. It's interesting, and I like it, but I have calculated it every which way I can think of, and I can't figure out what makes it 13 speeds. You've got 10 speeds, plus reverse, plus all the highs and lows.
It's driving me nuts. Just curious.![]()
13 Speed: Probably a stupid question, but...
Discussion in 'Questions From New Drivers' started by CoveringBases, Dec 21, 2016.
Page 1 of 16
You have lo, 1-2-3-4 in the bottom end so that's 5 gears.
Top end(once you've flipped the range selector on the front of the gear shift), you've got those same gears again. So where first gear is, you've got 5 low/high and then 6 low/high and so on. Some guys will call it 5 direct or 5 over but it means the same as high/low. So the top end you've got 8 gears essentially. 8+4 low end + lo adds up to 13.
An 18 speed is the same, however you've got 8 low gears also and you can split the lo gear too.G13Tomcat, blairandgretchen, Lepton1 and 3 others Thank this. -
18 speed is 9 speed that can be split in every gear. -
So let me get this straight a 13 speed is a 9 speed plus 4 or an 18 speed minus 5 or a 10 speed plus 3?
blairandgretchen and Dave_in_AZ Thank this. -
Hope you never get a 15
woodynva, johndeere4020, Dave_in_AZ and 2 others Thank this. -
Lepton1, Dave_in_AZ and Bean Jr. Thank this.
And tomorrow we will tackle the Mack tri-plex.lol
poppapump1332, MJ1657, johndeere4020 and 7 others Thank this. -
https://s-media-cache-ak0.pinimg.com/564x/3e/34/83/3e34835f655f03f09b83f5c7b707a96b.jpg -
With those explanations (without visual examples),I think it would be easier for him to understand Abbott and Costello's "Who's on First"
AtticusRoad, uncleal13, fargonaz and 5 others Thank this.
Page 1 of 16
