1994 Detroit 60 Series 12.7 jake brake problem.
Discussion in 'Freightliner Forum' started by davis28905, Sep 15, 2021.
  1. davis28905
    davis28905 Bobtail Member
    My 4cyl jakes act like they don't turn off when you hit the accelerator, clutch or even turn the switch off. They sound like they keep running for a few seconds after they should have cut off completely. 2cyl jakes work fine. Need to find a solution quick as this is my main rig. Thanks.
  3. davis28905
    Forgot to add it's a 1995 Freightliner FLD120 with a 1994 DDEC III 360hp motor. Thanks again.
  4. Big Road Skateboard
    6,050
    32,769
    May 2, 2021
    Probably a stuck solenoid, or sticking piston.
    Magoo1968 and Rideandrepair Thank this.
