1998 Freighliner Century Detroit series 60 water temp problem
Discussion in 'Refrigerated Trucking Forum' started by draya93, Sep 16, 2021.
  1. draya93
    draya93 Bobtail Member
    34
    14
    Aug 25, 2021
    I have a 1998 Freightliner Century with a Detroit Series 60. Running down the interstate at 65mph and water temp is normal at 180ish degrees and it randomly rises to 200 degrees and the fan kicks on but goes back to normal to 180-185 degrees within a second. It was doing this pretty often.
  3. RubyEagle
    RubyEagle Medium Load Member
    631
    777
    Apr 17, 2010
    Seems normal. Operating range is 190-210 IIRC. My fan kicks on at 200-205 f.
  4. draya93
    34
    14
    Aug 25, 2021
    I was told it was normal especially in the arizona heat, but wasn’t sure and wanted a second opinion. I’m fairly new to Detroit engines.
  5. Big Road Skateboard
    4,396
    20,928
    May 2, 2021
  6. draya93
    34
    14
    Aug 25, 2021
    Thank you, wasn’t sure if it was normal.
  7. Rideandrepair
    16,526
    53,944
    Aug 8, 2015
    Normal. If it stays hot, with fan on, radiators plugged or fins are blocked. Really unless it’s 95-100 degrees, loaded heavy, or up a hill. Fan shouldn’t come on at all. High A/C compressor pressure may be causing it. Being a 98, radiator could be getting old, especially if it’s original. Wouldn’t hurt to flush it good, sometime. Clean the fins up on it, and cac, and A/C condenser. Make sure it’s getting good flow. Meanwhile you can rinse it off good with water. First from backside, with engine off. No high pressure, just a garden hose. Then at idle, kicked up on high idle, maybe 1400-1500, with fan on, spray it from front. Sucks all the water through. Buys some time.
  8. draya93
    34
    14
    Aug 25, 2021
    Thank you, this is very helpful.
    Rideandrepair Thanks this.
