I need to know where the parking brake sensor is located , not the brake switch the parking switch , when you push in your air to move that sensor . Thanks guys
1999 Peterbilt 379 Detroit 60 12.7 sensor location
Discussion in 'Peterbilt Forum' started by rslivelyjr, Dec 8, 2023.
No cruise , No Jake - right? And wonky readings on speedometer? -
Check the tail shaft sensor - I believe that’s your speed sensor - remove, clean, reinstall - all the way in then back off 1.5 turns - jamb nut. Or replace.
Cruise and Jake - will be clutch or brake switch. Try wiggling clutch linkages and brake pedal when parked.
My problem was that some idjit had tapped into the ‘ground’ (which it is) circuit for another reason - they’re all white numbered wires.
TPS shouldn’t affect it. -
