2 axle interlock
Discussion in 'Questions From New Drivers' started by mitmaks, Mar 13, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,560
    2,075
    May 16, 2014
    So which axle does interlock engage, front one closer to cab or rear axle?
    I was told that your full time drive axle is front one and axle switch engages rear one.
    I saw people put chains only on front axle, wouldn't you want to put chains on front axle-closest to the cab?
  3. 51.50
    51.50 Heavy Load Member
    894
    1,942
    Jan 20, 2016
    Salem Oregon
    There are different designs. They are not all the same. On the last set I had the rear axle had full time drive and when you engaged the power divider, you were locking in the front axle.
    mitmaks Thanks this.
  4. Accidental Trucker
    Accidental Trucker Road Train Member
    3,358
    7,381
    Jun 4, 2015
    Neither. Interaxle lock ties both axles together. Both axles are live with an open differential between them when unlocked.
    Oxbow and Bean Jr. Thank this.
  5. AModelCat
    159,170
    I'd really like to know who keeps telling people the front axle is full time live and the rear one is only live when the inter axle is locked in. Its gotta be one of the biggest myths in trucking.
    OP, inter axle lock locks your front and rear drive axles together so they both split 50% of the power under all conditions. Axle locks lock the left and right sides together on each axle so that both sides are putting power to the ground.
  6. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Yup. If you understand how these things work it makes no sense to say you have one live axle.
    If you only have chains on one axle you have to use the power divider some times. You shouldn't be going very fast with chains anyway.
  7. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    The guys that are chaining one drive have tag axles.
    You can look and see if the driveline goes back to the rear to see if its live or tag. Its real easy to spot the difference.
    I've chained several super single tag axles in my time at Conway otr. Topped off with bleach and kitty litter xD
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,504
    9,788
    Mar 30, 2014
    A mechanic at Hunter Peterbilt, Jersey Shore, tried to tell me that. I told him he must be one of the new guys. He then told me.he was the axle expert. I walked away, shaking my head!
    AModelCat Thanks this.
  9. Bean Jr.
    5,504
    9,788
    Mar 30, 2014
    Although everybody refers to it as a "power divider", it's really called "inter-axle differential lock", and that should answer the question. There is a differential that puts power to both axles, just like a differential puts it to both wheels. Whichever of the four loses traction, that is the wheel that will get the power. In order to make sure that at least one wheel per axle will turn, you lock up the power divider, then if either axle has traction at both wheels, you'll move.
    WitchingHour Thanks this.
