20 year driver, newbie to snow chains!
Discussion in 'Questions From New Drivers' started by Jaybird8955, Nov 24, 2017.
  1. Jaybird8955
    Jaybird8955 Bobtail Member
    5
    Nov 14, 2017
    I’ve always run regional in the Southeast. Now driving nationally. Snow has NEVER been an issue before. I have just realized that I need to figure out how to put on snow chains! LOL!
    You tube, I guess?
    Dan.S and Lepton1 Thank this.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Practice now, while it's dry & sunny so you will be prepared when it isn't.
  4. WesternPlains
    6,298
    53,164
    Sep 1, 2017
    Welcome to the wonderful world of snow chains. :p
    First things first: Make sure you have an insulated pair of chemical gloves. The chemical gloves are rubber (or whatever) coated so no water gets through. You'll thank me.
    Second.... Chains are a PIA!
    Third.... They won't last long before breaking or wearing out. Use sparingly.
    Fourth... There are different ways. (either way you fight :biggrin_25516:) to get them on right. Look up the 'board" or 2x4 way. They say it makes it easy. The double chains are especially hard to get on. Seriously...singles aren't that bad. With singles.... you'll be back in the cab with your hot cocoa, and teddy bear, pretty quick.
    Fifth... No matter what. Drive a little after putting them on. Then stop and check them. Bungi cords are your best friend with chains.
    okiedokie and Jaybird8955 Thank this.
  5. supersnackbar
    19,064
    46,867
    Aug 19, 2007
    Your Town, USA
    Screw bungie's.....snow spiders, unless you work for a company that has snow socks, then don't use socks on pavement, only on snow/ice
  6. skellr
    skellr Road Train Member
    8,737
    12,185
    Jul 17, 2011
    The Village, Portmeirion
    Yeah.
    I like to put them on tight. When you hook the inside try to hook it as tight as you can. Sometimes this will leave you with extra chain that will whip around, you can put the end link on the hook and hook again further down the chain to get it tight.
    Make sure all the cams are open and hook the outside as tight as you can. If you got both sides tight enough you won't need bungees to take up extra slack In the chain, they will be tight like Huggies.
    J Man, JReding, Dan.S and 1 other person Thank this.
  7. skellr
    8,737
    12,185
    Jul 17, 2011
    Reason for edit: Otter!
    not4hire Thanks this.
  8. "CookieMonster"
    "CookieMonster" Bobtail Member
    Nov 24, 2017
  9. "CookieMonster"
    Nov 24, 2017
    Hey,Jaybird: Been OTR for over 50Years. Give this a thought! Some Drivers believe,"If I NEED chains (I AM SAFER IN A TRUCK STOP)Then I can wait till after the snow plows finish. Once upon a time that was me!
    No company I'VE WORKED for ever gave me a hard time for choosing "SAFETY". You have to feel It's worth it. Then have one of us OLD TIMERS help You. I'm not the only one to help a fellow trucker. You can ask another driver to help you and you'll help right back! It is easier to gang up, two Drivers against one Chain Hanging! HA-HA! Good Luck! See you out there Some time! They call me "CookieMonster" The one, The only "CookieMonster"! (I've been the COOKIEMONSTER B4 Sesame Street). -10-4-,?
    Oldironfan and Jaybird8955 Thank this.
  10. Dan.S
    Dan.S Light Load Member
    278
    7,747
    May 10, 2017
    Chains are NOT hard to put on.
    No clue why people make them out to be such a nightmare.
    Drape the chain over the top of the tire, with ends situated appropriately. Then, attach ends of chain to each other. Pull forward (or back up) so the end links are not on the bottom of the tire, and take up slack.
  11. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    My rule for chains...unless I am stuck, if it is bad enough to use chains, I donr drive.
