hello all recently bought a kw t600, however the alarm buzzer for low air and im guessing for engine problems is not working (or maybe unplugged by last driver) , i was told by a mechanic behind the dash (speedo section) there is 2 connections attached to a firewall and those are for the alarm but im not sure if the buzzer is in there i always though it would be up top where the light bar is.
anyways how i can find this problem out need to fix this since its important for DOT inspection
2000 kenworth t600 alarm buzzer location?
Discussion in 'Kenworth Forum' started by ScarfaceTrucking, Aug 18, 2020.
I may be wrong, but all you need is one,
A light, a buzzer, or a wig wag...I know some won’t know what that is so here’s a photo.
Just a stem that lowers down in your view to say low air.blacklabel and ScarfaceTrucking Thank this. -
Does a 2000 model still have the warning light bar above the steering wheel?
On my 87 & 95 models that is where the buzzer was located.ScarfaceTrucking and spsauerland Thank this. -
thanks yes after looking around at the light bar it appears that last owner disconnected to buzzer so easy fix it now works
