2013 ISX15 running hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jul 27, 2021.
  1. mitmaks
    mitmaks Road Train Member
    2,557
    2,072
    May 16, 2014
    I've got '13 isx15 450hp that seems to run hot. I'm climbing hills and with a/c off and fan on it can barely keep temp under 210F
    I'm thinking maybe I have blockage in radiator somewhere. What can I do to help keep it cool?
  3. Big Road Skateboard
    6,051
    32,798
    May 2, 2021
    First, blow the radiator out from the inside forward. It's likely got some external flow issues. Keeping RPM's up on hills will help keep temps down too.
    What RPM are you pulling these hills.
    mitmaks Thanks this.
  4. mitmaks
    2,557
    2,072
    May 16, 2014
    Generally 1500rpm going 25-35mph pulling 40-47k
  5. Big Road Skateboard
    6,051
    32,798
    May 2, 2021
    You'd run cooler at 1750-1800. You must be on some huge hills ar 25-35 mph.
    Nonetheless, the lower that RPM is, the harder that engine has to work.
  6. mitmaks
    2,557
    2,072
    May 16, 2014
    Water pump was replaced last year
  7. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    My truck ran 192* empty. New radiator and thermostat, it runs at 180*. Climbs when I pull a hill. But even in cases like you, if I flip the fan on, it runs at 176* grossed, and pulling a hill for five minutes straight in 6th gear.
    Point being, your manual fan should be able to control your temps perfectly if everything else is right.
    spsauerland and mitmaks Thank this.
