2016 Freightliner Cascadia Evolution Automated Manual Transmission Help
Discussion in 'Experienced Truckers' Advice' started by X-Country, Apr 24, 2017.
  1. Brandt
    Brandt Road Train Member
    4,599
    6,311
    Sep 17, 2012
  3. X-Country
    X-Country Medium Load Member
    645
    462
    Mar 27, 2014
    I couldn't help but snicker when they said snub brake till you achieve the desired speed (is that before or after you burn your brakes up because it's already going to fast down the grade? don't answer that, just dry sarcasm.)
    Thanks for the video. Just as I suspected.
    fargonaz Thanks this.
  4. mustang190
    mustang190 Road Train Member
    2,870
    6,180
    Jan 18, 2011
    Florida Panhandle
    Maybe I missed it, but what kind of engine is in the truck? It makes no difference what brand of TRUCK it is it's the engine and transmission manufacturer, along with the rear end ratio determines how the Jake's work.
  5. JReding
    JReding Road Train Member
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    I'm checking with Freightliner right now, but if I'm not mistaken, they exclusively use Detroit now.
  6. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    Yes but the first generation Freightliner auto was called SmartShift. Like all auto cars and pickup trucks, you'd slip the little selector forward or away from you for Reverse and back or toward you for Drive.
    Evidently some engineer at Freightliner who mows his lawn with an auto riding lawnmower and plays golf with an auto golf cart, both of which you push the lever forward to go forward and back to go back, thought it would be a brilliant idea to bring that tech to the world of 80,000 guided smart ground traversing torpedos lol
    JReding Thanks this.
  7. JReding
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    Oh, piffle...
    BTW, have I shown you our new uniforms yet? Quite comfortable in the driver's seat, just not sure about the color... 20170426_134344.png
    LloydToo, scottied67 and tscottme Thank this.
  8. cd066
    cd066 Light Load Member
    50
    51
    Dec 16, 2012
    Richmond, VA
    Is this a company truck or is it yours?
    If it's a company truck it has a company profile on the ecm which will include shift points they want. Good luck getting that changed. If it's your truck then you can modify the shift points and how aggressive you want the engine brake to operate.
  9. X-Country
    645
    462
    Mar 27, 2014
    DD15
  10. Brandt
    4,599
    6,311
    Sep 17, 2012
    Their is a Descent Mode on the Detroit transmission. It will hold the the truck at the speed you set it at.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Tosses coffee across the room.
    Cowardly engineers.
    If you cannot jake at the red line which sometimes works out that way compared to shifting up and finding yourself with super lugger incorperated and not enough jake to hold er.
    Manual should be just that. Manual mode stays in the gear you picked. Otherwise it's joke. A pile of BS blowing smoke up fleet purchasing officer's butt.
