The frame has cracked just under 1st axel mounting bolts, both on left and right sides.
2019 EAST flatbed frame is cracked - is it normal?
Discussion in 'Flatbed Trucking Forum' started by AlexRider3, Aug 17, 2024.
aluminum trailers are bad about that when they’re about 5 years old.
AlexRider3 Thanks this. -
Cracked frame is an OOS violation.
Normal no, but it happens a lot.AlexRider3 Thanks this. -
Hopperbottom do same with aluminum, i keep steel frames.AlexRider3 Thanks this. -
I would be surprised if they actually have the title to most of the equipment in the yard/
You can pick the best turd on the lot, spend a bunch more to have it fixed, then lose it when they file bankruptcy in november anyway-
Or
You can cut your losses and move on: See if you got enough left in your account to make your own venture successful.
You are too close to see what’s happening: I can see the whole picture from here though.W923, Oxbow, Concorde and 1 other person Thank this. -
Crazy. I drove for a company and trailer I had was 2012. Trailer structure was spotless m. It was all aluminium east trailer too
I have a 2016 east step deck, just did Air bags and shocks on it yesterday and inspected for cracks. Frame is clean as can be, and I’ve loaded the heck out of this trailer. Carefully of course.
CAXPT, cke, AlexRider3 and 2 others Thank this. -
I looked at a Benson 524 2016. It had twenty cracks in the kingpin area. The main beam had one small one. The rest were crossmembers.Anyone
Does anyone have any idea what happened there? I have owned three aluminum trailers and never had any issues. I would not say its normal.AlexRider3 Thanks this. -
Watching a company driver whip u-turns with a loaded spread axle in the truckstop vs. an owner op swing wide and take his time is a simple observation I've made over time. I would assume 2 identical trailers pulled by 2 different drivers could have much different lifespans. Just an observation though...
