3.42 ratio vs. 2.64 ratio on cascadia
Discussion in 'Freightliner Forum' started by miroelle, Jan 13, 2016.
  1. miroelle
    miroelle Bobtail Member
    21
    May 8, 2015
    Hi guys, i have a dilemma. i was offered two *11cascadias but with different ratio- 3.42 and 2.64. Both Detroit engines, 10 speed trans. Which one should i go for? Is there a big difference in power when crossing mountains? Thank you
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Does the 3.42 have a direct trans. like the 2.64 does?
  4. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The 3.42 would be a overdrive trans . Would feel about the same in high gear. The 2.64 will give better mileage . Startiablity would be about the only difference . How often can you not start off in second gear?
    miroelle Thanks this.
  5. blairandgretchen
    13,266
    70,886
    Dec 9, 2011
    South west Missouri
    Grab the transmission ID, and the VIN, cross reference them with tranny maker and truck maker, 2.64 most likely a direct drive - as said, probably better MOG, unless startability is a factor.
  6. miroelle
    21
    May 8, 2015
    thank you, guys. 2.64 is direct, 3.42 is over. i know that , i just wasnt sure if i would feel the difference while crossing mountains. i guess not much, right.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    I would buy 3.42 .
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    You won't notice a difference in the hills. It is only on start up from a dead stop. Takes a tad bit more time to get up to speed with a direct and 2.64. I run heavy on some very hilly rural backroads highways from time to time using a 18 speed in front of 2.64, and I have no problem. The direct and 2.64 can edge out a 10 OD with 3.42 on fuel economy, but that is also dependent on the driver and speed you typically run.
    The key is the RPM range the engine is in and the engine in question. At 65 mph, a 10 direct with 2.64 will have you turning about 1475 RPM on low pro rubber. With a 10 OD (usually something like a .73 or .74 OD) with 3.42, and you will be turning about 1400 RPM at 65. That should give you a general idea of the difference. With the DD15 and a choice between those two, I would probably go with the 3.42. For something like a Series 60 12.7, I would opt for the direct and 2.64. It is all about the engine as well as the trans and rear gear.
  9. jim3029
    jim3029 Bobtail Member
    38
    11
    May 27, 2012
    Janesville,WI
    Cowpie I have a coworker who is getting ready to order a glider with a 13 speed and 2:64. Just wondering what you think of that combination. I believe it will be a C-12 with a liftable axle since we run light and come back mostly empty.
  10. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Well, given that the conditions are primarily light or empty, I would just go with a 10 speed direct and 2.64. The only appreciable advantage of a 13 or 18 is working grades with heavy loads and keeping the RPM's tighter. A 10 speed direct is a very solid trans, is lighter, and works great for what you are describing. Of course, if one is wanting to bust the sound barrier down the highway, a direct would have the RPM's pretty high with no where to go. Then maybe a 13 might be a good option to move on up to OD at the higher speeds.
    J.S. and jim3029 Thank this.
  11. jim3029
    38
    11
    May 27, 2012
    Janesville,WI
    Well we do have a couple runs were you have to run 68 to 70 most of the day or you'll be sleeping 1/2 hr from home but no faster than that. Thank you.
