3406e oil in fuel tank
Discussion in 'Ask An Owner Operator' started by W9in’, Jun 5, 2021.
  1. W9in’
    W9in’ Bobtail Member
    15
    11
    Sep 29, 2019
    I only took it to him to change my steering gear box have no idea why he was snooping around anyways. But yes I usually go to cat for motor work
    feldsforever Thanks this.
  3. Largecar359
    Largecar359 Road Train Member
    1,075
    1,323
    Aug 13, 2011
    New Jersey
    Pull THE HEAD? Run, Don’t play around there. If your gonna pull the head, replace it. Injector cups, injectors, all that will be done with the head on the block. Unfortunately, this is most likely how it will go. Once he pulls the head, there will be other issues that require your attention, and he will be selling you a motor job. From his side of things, it’s much easier to sell a motor job to a customer when the motor is already apart. Once the head is off there isn’t much more to do, all the labor and $$ is up Top on a Cat.
    Farmerbob1, slow.rider and W9in’ Thank this.
  4. Largecar359
    1,075
    1,323
    Aug 13, 2011
    New Jersey
    Keep a eye on it, white smoke with that motor can be a early sign of rebuild time. Low compression in one or two of your cylinders causes white smoke, unburnt fuel, then it clears up as you throttle up and heat rises in the cylinders.
    feldsforever, slow.rider and W9in’ Thank this.
  5. W9in’
    15
    11
    Sep 29, 2019
    Most definitely running lol
  6. W9in’
    15
    11
    Sep 29, 2019
    10/4 and I don’t mind a rebuild when it’s actually time. Not because someone’s trying to make some cash. I texted him and told him I’ll pick it up Monday and pay for what he’s done. Thanks y’all
    slow.rider Thanks this.
  7. Big Road Skateboard
    4,395
    20,918
    May 2, 2021
    You need a fuel analysis, not oil. My apologies if I misspoke earlier. I also didn't mean to discount the possibility of a loose injector, or bad injector o-rings in my earlier post, cause they are definite possibilities. But if injectors were removed and o-rings inspected, you would find it if the failure was o-rings or cups. If you see no sign of issues with either of those, you would then look towards an injector not sealing.
  8. Rubber duck kw
    6,084
    17,657
    Dec 9, 2017
    It down on power any? If it's been running normal I'd tell him not to worry about it for now you'll keep an eye on it. Algea will do that to fuel I'm pretty sure, and all the biodiesel you get at the big fuel stops doesn't help any in my opinion.
  9. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,784
    Jan 17, 2017
    Have you had an oil sample taken? By someone else?
    I find it difficult to believe you could have oil in your fuel without also having fuel in your oil.
    I cannot think of any places where oil and fuel could mix where the oil is much higher pressure than the fuel. Fuel going to the block is very high pressure, and oil doesn't get near the oil on the low pressure side of the fuel system on it's way back to the fuel tank. The contamination can be one-way only if the pressure differential is large and the leak is small, and even then there would likely be measurable traces even if they are tiny.
    feldsforever and slow.rider Thank this.
