60 series Detroit won’t start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Iron diesel, May 23, 2021.
  1. Iron diesel
    Iron diesel Bobtail Member
    5
    8
    May 23, 2021
    I have a 95 L9000 that will not start after sitting the winter. I have fuel right up to the head and spits out the return when I crack the lines, it doesn’t even kick on ether. Any thoughts?
  3. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Only thought I have is cam and crank sensors, but doesn’t make sense that it simply sat over winter and won’t start.
    That’s the only ‘no start’ issue I’ve had with mine.
    Bean Jr. Thanks this.
  4. jsnell
    jsnell Light Load Member
    253
    343
    Apr 12, 2016
    Check battery box for bad or chewed wires. you need fuel, compression and power to the ecm.
    jamespmack Thanks this.
  5. jsnell
    253
    343
    Apr 12, 2016
    Check the battery box for corroded or chewed wires. You need power to the ecm. There is a fuse on my n14 don't know about 12.7. My fuse is on small wire in battery box.
  6. jamespmack
    215,825
    With key on, engine off. Do you have cel,sel?
  7. Iron diesel
    5
    8
    May 23, 2021
    Fuses are good, maybe I’ll try new crank and cam sensors.
  8. Iron diesel
    5
    8
    May 23, 2021
  9. Iron diesel
    5
    8
    May 23, 2021
    No check engine light on.
    Vampire, jsnell and blairandgretchen Thank this.
  10. jamespmack
    215,825
    If it does not cycle, come on and go out with key. You do not have battery voltage to ecm. Check power wires and fuses like other recommended.
    Vampire, spsauerland, jsnell and 2 others Thank this.
  11. jamespmack
    215,825
    If the SRS, TRS sensors are bad. They normally will fire on either and stay running till you shut it down.
