76 Kenworth won't turn off with key
Discussion in 'Kenworth Forum' started by 76K100, Mar 27, 2023.
  1. 76K100
    76K100 Light Load Member
    55
    89
    Mar 13, 2023
    WISCONSIN BUT FROM NOR CAL
    hey guys anybody know why my k100 won't shutoff when I turn key to off position?
  3. Oxbow
    Oxbow Road Train Member
    13,331
    138,054
    Nov 24, 2015
    Cummins?
    76K100 Thanks this.
  4. Judge
    89,782
    I once wired my AC compressor to starter.
    It quit kicking on, that locked it engaged while key was on, but completed the circuit, you could turn off key and put it on pocket, just killed your gauges.
    Had to stall in gear.
    Oxbow Thanks this.
  5. 76K100
    55
    89
    Mar 13, 2023
    small ca
    small Cam Cummins and im not talking bout dieseling it stays running. thanks
    Oxbow Thanks this.
  6. Oxbow
    13,331
    138,054
    Nov 24, 2015
    Make sure the thumb screw on the pump didn't get screwed in for starters.
    Bean Jr., Diesel Dave and 76K100 Thank this.
  7. 76K100
    55
    89
    Mar 13, 2023
    it didn't I was shuting off fine when I left 3 weeks ago then got home to let it run for a few and wouldn't turn off. I was out in my otr truck the k100 is a project
    Oxbow Thanks this.
  8. Inderjit
    Inderjit Heavy Load Member
    742
    721
    Sep 17, 2017
    See if there is power on the terminal on the fuel solenoid with the key off.
    Bean Jr. and 76K100 Thank this.
  9. Tumbleweed TowMan
    Tumbleweed TowMan Medium Load Member
    390
    1,714
    Jun 22, 2022
    Sounds like bad ignition switch.
    jsnell and Bean Jr. Thank this.
  10. 76K100
    55
    89
    Mar 13, 2023
    if there is power does it mean bad switch?
    Oxbow Thanks this.
  11. 76K100
    55
    89
    Mar 13, 2023
    and where is the fuel solenoid on a small Cam Cummins?thanks
