90 alley dock and offset back
Discussion in 'Questions From New Drivers' started by 1278PA, Nov 30, 2017.
  1. 1278PA
    1278PA Road Train Member
    1,170
    1,026
    Dec 5, 2015
    Some of you may remember me and guess what I've finally started this career. I'm 9 days into schooling with a company.
    We recently started backing and I'm having kinda a tough time with it. We started backing this Monday but most of it the trainer stood outside with my window down telling me step by step how to do it. Now today was really the first day doing backing mostly without his help and I struggle more with the offset.
    I can drive the truck shifting is real good downshifting sometimes is an issue but most of the time I get it. I have to work on downshifting quicker before getting to a light or stop sign. Sometimes I only get down to 6th and just reset to my starting gear.
    Other then that for the CDL test I'm confident on the pretrip and the driving and shifting part for the most part just not the backing yet.
  3. mitrucker
    mitrucker Road Train Member
    5,232
    9,239
    Dec 15, 2010
    Lapeer, MI
    Backing takes time to master. Stay with it and by all means control you temper. Getting all bent out of shape doesn’t help. Also keep in mind that we all have days where backing is just plain tough. Other days, it’s cake.
    SingingWolf Thanks this.
  4. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    Yeah, you’re basically where we ALL were at that point. In other words-you’ve got em right where you want em. ;-). Congrats on getting going. Been a long time coming.
    KillingTime and 1278PA Thank this.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    You pivot on the trailer tandems... meaning you put the tandems where you want the trailer to pivot... but you have to watch where the tandems are in relationship to the rear of the trailer. If they know the zig-zag movement to get you placed the better. you drive in front of the other noses of the tractors, then once you are at your spot you take a 45 deg out, then zig zag to place the trailer at an angle to the slot.
  6. 1278PA
    1,170
    1,026
    Dec 5, 2015
    For the offset we are learning right to left. Instructor tells us fist move is hard right and get the trailer to close to a 45 degree bend. Some guys say only one revolution of the steering wheel right is all you need to start. So many people say different stuff it's all a jumble in my head.
    Also this may sound funny but sometimes I get up there and don't know which way to turn the steers I have a complete loss of thought for some odd reason. Because sometimes turning the wheel left does the same thing as turning it right it seems in certain situations. Once I can see the cones in both mirrors I'm pretty good I think at getting it in the hole. It's just somewhat in the middle of the manuver I get screwed up.
  7. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Think where you want the rear of the trailer to be and then steer to place it there... Watch the end of the trailer in the mirror and steer to move it... It takes practice...
    1278PA Thanks this.
  8. HighwayD
    HighwayD Light Load Member
    58
    61
    Nov 15, 2017
    Pennsylvania
    Congratulations, driver! Good luck. It will be tough for a while so don't get discouraged and make sure to listen to the old timers. Most of them will only say it once!
    1278PA Thanks this.
  9. TommyTrucker88
    TommyTrucker88 Light Load Member
    165
    135
    Nov 16, 2016
    POCONOS, PA
    Good luck in your new carrier. The job gets easier if you treat it with diligence.
    Best advice I can give anyone is use the Smith system and if you don't know it go and study it and recite it back to yourself and think about how it works and how 95% of accidents can be prevented. And make sure to use goal.
    Nothing will screw you over faster then getting a ####y attitude and be over confident with your ability to operate a 18 wheeler safely and efficiently .
    If other drivers are staring at you, trying to speed you up, making you feel nervous, remove them from your mind. You are a professional driver doing your job and there's nothing embarrassing about being new or not experienced.
    What will be embarrassing is when you get into a problem you could of avoided.
    Drive safe and take your time.
    1278PA Thanks this.
  10. gentleroger
    gentleroger Road Train Member
    7,414
    20,110
    Jun 1, 2010
    When I back Im looking at three points - the dot bumper, the tandems, and the nose/tractor angle. Those three things will tell you where the trailer will go.
    I try and put the trailer 1 foot away from the object on the sight side. If the dot bumper and tandems are both the same distance then Im straight. If not, then Im still at an angle.
    Also get out and look, even when not necessary. Seeing things from the outside will help things make more sense.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    I tend to drop a trailer into any old spot in one move. The auto makes sure of that. However. I did not have that ability until about 20 years into my time out there on the road. I actually smashed the old west coast mirriors in many places paying them 20 here 20 there 20 more there... until I stopped smashing them and got better.
    That was literally my school in backing. 20 at a time.
    If I can do it, as dumb as I am... you can too and way sooner than 20 years.
    1278PA Thanks this.
