95 Kenworth T600 tach
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Faviang9, Sep 10, 2021.
  1. Faviang9
    Faviang9 Bobtail Member
    Sep 7, 2021
    95 Kenworth t600 12.7 Detroit with a 13 speed. I’ve replaced the tachometer gauge with a new one, new tachometer/ speed sensor. And I’ve gone through all the wiring. Still can’t get the tachometer to work. Any ideas?
  3. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Amtek replacement tachometer?
    I have 95 379 with 12.7. Amtek replacement wouldn’t work. Friend sent me a used Peterbilt guage. I returned the Amtek.
    Still no idea why it wouldn’t work.
  4. Faviang9
    Sep 7, 2021
    I bought mine brand new from Kenworth
    blairandgretchen Thanks this.
  5. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    So - KW branded? Like original?
    Did you set sensor correct? Usually all in, then back off 1.5 turns and set jamb nut.
    Test continuity of wires. Resistance of sensor.
  6. Faviang9
    Sep 7, 2021
    Yes sir original. And yea I did
  7. Inderjit
    Inderjit Heavy Load Member
    723
    708
    Sep 17, 2017
    Measure the resistance of the sender under the truck and then plug
    it back in and measure the resistance at the plug where it connects
    to the tachometer. It should be the same. Also make sure there is
    power and ground at the tach.
