A/C needs more power
Discussion in 'Kenworth Forum' started by miguelmorales, Jun 4, 2016.
  1. miguelmorales
    miguelmorales Bobtail Member
    10
    Jun 4, 2016
    I have a 2007 Kenworth t600 and the a/c unit isn't blowing much air. I have already taken it to have it looked at and everyone says it is working properly. The problem is that it doesn't have much power the air is cool but much isn't coming out. Any advice on what it could possibly be?
  3. bigmotor1212
    bigmotor1212 Light Load Member
    256
    363
    Dec 20, 2014
    Is it possible the blower speed control isn't working? It's only running on one speed?
    miguelmorales Thanks this.
  4. miguelmorales
    10
    Jun 4, 2016
    All four speeds are working and you can feel the increase in airflow but it isn't anything dramatic.
  5. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    You will have to look under dash for a air duct hose thats off and just blowing under dash an not out vents?
    blairandgretchen Thanks this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Or blower motor is weak. Restate maybe bad. Evaporater may be plugged with dirt.
    ExOTR and blairandgretchen Thank this.
  7. AModelCat
    158,634
    Don't know if the T6's are like the T8's but check the air intake for the HVAC system, it should be above the pass. side fender, around where the air breather is. Some people install the optional cab air filter over the mesh there. Or if you don't have a cab filter dust can actually take out the fan over time.
  8. miguelmorales
    10
    Jun 4, 2016
    Thank you everybody for all the feedback! It's all really helpful.
  9. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Check your in-cab filter, if you have one. If it's clogged up, it will slow your flow. The system can only blow out what can get sucked in. A dirty fan will not be as efficient either.
  10. Ridgeline
    22,380
    116,160
    I have this issue with a couple older trucks, and the western stars at one customer. If I try the air con and it is blowing warm air out or marginally cooling down the cab, I go under the hood and shut the heater lines off. For some reason this cures the problem.
  11. blairandgretchen
    13,376
    71,897
    Dec 9, 2011
    South west Missouri
    Just don't shut off the line to the transmission cooler . . . Yeah, I did that.
    ExOTR Thanks this.
