ABS light on J1939 code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 23, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,579
    2,093
    May 16, 2014
    I was driving my truck yesterday and all of sudden ABS light turned on the dash and then went out shortly and then would randomly flash. It gave me J1939 code, what could possibly be an issue?
    2013KW T660 ISX15
  3. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Google abs and the code. Something will come up for sure.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Did you ever find anything? Or is it even still happening?
    In my experience, when it comes on and off like that it's a loose sensor. I'd unplug each wheel sensor, put a little dielectric goop on each and make sure they plug and snap in.
  5. mitmaks
    2,579
    2,093
    May 16, 2014
    I drove truck to the shop today and it was fine. I noticed abs light on trailer wasnt coming on and boss told me it possibly caused my truck abs to act up? I hope it doesnt come back on again.
  6. mitmaks
    2,579
    2,093
    May 16, 2014
    I think its related to axle seal leaking.
    I was doing post trip and found huge leak on inside of wheel. I was at Loves and mechanic took rim off and showed me that actual hub bolt was loose and so it wobbled both bearings and they were damaged and seal was replaced along with new gear fluid.
    There is locking hub but ring that never got locked by previous ####### that worked on it. Grease build up gave ABS error.
    uncleal13 Thanks this.
  7. mitmaks
    2,579
    2,093
    May 16, 2014
    Mechanic at Loves installed one of these locking hub nut retainers to make sure axle nut doesn't come loose again
      File size:
      21.8 KB
      244
  8. Shashamane
    Shashamane Bobtail Member
    19
    6
    Feb 6, 2017
    Did you ever find this ploblem
  9. mitmaks
    2,579
    2,093
    May 16, 2014
    Yes ended up hub nut loose/leaking wheel seal. It was loose enough that whole hub would wobble thus and toner ring would detect fault
  10. Shashamane
    19
    6
    Feb 6, 2017
    Thanks alot.will check it inthe morning
  11. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    J1939 is an SAE communications standard.
    AModelCat Thanks this.
