Accurate air scale
Discussion in 'Ask An Owner Operator' started by mitmaks, Apr 18, 2025.
  1. mitmaks
    mitmaks Road Train Member
    2,544
    2,065
    May 16, 2014
    Looking to get air scale for truck and trailer. Truck has psi gauge that shows approximate weight but wanted to see what everyone else would recommend.
  3. FullMetalJacket
    FullMetalJacket Road Train Member
    3,183
    4,601
    Oct 16, 2013
    Vagrant
  4. Diesel Dave
    8,536
    23,624
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on Right Weigh. I have it.
    D.Tibbitt, FullMetalJacket and Oxbow Thank this.
  5. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I just ran gauges into my truck off of the airbags on the truck and trailer.
    I think they were like $10 on Amazon. Plus fittings and Airlines.
    Once you know how your truck is loaded, you know right where your gauges need to be.
    Always worked for me.
  6. 201
    201 Road Train Member
    12,069
    24,637
    Apr 16, 2014
    high plains colorado
    Same here, and they were surprisingly accurate. 63 pounds on the gauge was pretty darn close to 34K. Pulling containers with no rear slider, saved my aXX many times.
  7. MacLean
    MacLean Road Train Member
    1,278
    3,737
    Sep 12, 2017
    Yes, air gauges will do. Get loaded legal, Marx the gauges with a permanent marker and you’ll be fine. It’s essentially the same thing. The scale company setup is just turning the air pressure into a weight number and I do believe you
    Need to load legal to calibrate it th first time as well so no difference other than cost.
  8. D.Tibbitt
    141,322
    Times 3 on right weigh scale system... I could load my truck and trailer every single day at the rock quarry with a right weigh on trailer and factory psi gauge on drives and know where I'm at within 500 pounds...
  9. Big Road Skateboard
    5,713
    29,850
    May 2, 2021
    I've got the RightWeigh in my dash and on the back of my trailer.
    Load heavy, get a scale ticket, adjust your weights on the gauges, roll with confidence
  10. abyliks
    abyliks Road Train Member
    3,754
    8,705
    May 2, 2010
    ludlow MA
    Air guage anywhere past the leveling valve, scale empty, take tare and divide by psi, to figure out how many pounds each psi supports, (485 lbs x 80 =38800) costs like $15 for water filled guage and fittings
    then load it till it’s full and roll anyway….
  11. Dino soar
    4,789
    26,858
    Dec 8, 2017
    The right weigh system may be easier to install, although it will cost more.
    If you put air gauges you have to run Airlines and buy some fittings.
    It's not expensive, but it might take you a little time to run the airlines up to the front of the trailer and to run Airlines into the cab.
    I think either way is accurate, it just depends how much work you feel like doing versus how much money you feel like spending.
    D.Tibbitt and FullMetalJacket Thank this.
