Air build up in emergency line on trailer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jul 2, 2025.
  1. mitmaks
    mitmaks Road Train Member
    2,560
    2,075
    May 16, 2014
    I've noticed that once I've set brakes on trailer and went to unhook the emergency air line there was a ton of air pressure. I've never had it happen before.
    Once I've disconnected the air line there was air flowing out of gladhand on the trailer for like 20-30 seconds. Something on the trailer broke for it to backflow like that?
  3. Tb0n3
    Tb0n3 Road Train Member
    4,582
    9,167
    Oct 5, 2012
    Earth
    There's some valving that should keep that from happening. Should allow building air in the trailer tanks but not back feed. Yes there's something wrong with the trailer.
    mitmaks Thanks this.
  4. kwswan
    kwswan Road Train Member
    1,948
    10,343
    Jul 26, 2009
    mcminnville,tn.
    Your quick release valve on the trailer is bad.
    little cat 500, Tb0n3 and mitmaks Thank this.
  5. mitmaks
    2,560
    2,075
    May 16, 2014
    Is it easy to replace myself or needs specialty tools etc
  6. nikmirbre
    nikmirbre Road Train Member
    5,431
    9,811
    Jul 27, 2011
    High Point NC
    Its a valve that should be located near one of your front brake chambers....... no specialty tools needed. Just make sure you put the hoses back in the correct holes they came out of.
