Air Compressor cycles between 115 and 125 psi
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shawn19, Oct 20, 2022.
  1. Shawn19
    Shawn19 Light Load Member
    117
    34
    Apr 20, 2019
    My air compressor come on at 115 and goes off at 125 what would cause this do I need to replace the Governor
  3. DUNE-T
    DUNE-T Road Train Member
    7,020
    17,079
    May 10, 2015
    Detroit, MI
    You can adjust it
    Opendeckin and MartinFromBC Thank this.
  4. Shawn19
    117
    34
    Apr 20, 2019
    I going to try that hopefully it one that adjustable.
  5. MartinFromBC
    2,769
    12,483
    Oct 19, 2018
    Is there a problem with 115 to 125?
    Diesel Dave and Opendeckin Thank this.
  6. Opendeckin
    Opendeckin Medium Load Member
    467
    1,298
    May 20, 2018
    This. I usually set mine to kick on at 105 and cut out at 120, but 115/125 isn't bad IMO.
    MartinFromBC and Diesel Dave Thank this.
  7. Shawn19
    117
    34
    Apr 20, 2019
    Yes it a problem purging every 30 seconds normally should be coming on at 95 psi not 115
  8. Dave1837
    Dave1837 Road Train Member
    1,402
    4,348
    Nov 16, 2019
    Pennsylvania
    If it's dropping 10 psi every 30 seconds that truck should be out of service
    Concorde Thanks this.
  9. AModelCat
    161,606
    Sounds like you've got an air leak.
    Concorde and RJM1953 Thank this.
  10. Shawn19
    117
    34
    Apr 20, 2019
    You all were wrong it was a bad governor change out it an problem fix.
    Brettj3876 Thanks this.
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I just replaced the valves in the dash about a month ago. It would leak down from 125 to 100 in about a minute but you could hear it in the dash. And if you pressed real hard on the buttons it would stop. Pretty sure the Bendix one in there that was leaking was a Chinese knockoff. The new Bendix one had Bendix stamped in like 6 places where the old one had it labeled Bendix in one spot.
    But I see yours was a bad gov
