Air dryer purge valve leaking air overnight?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Apr 20, 2025.
  1. mitmaks
    mitmaks Road Train Member
    2,560
    2,075
    May 16, 2014
    It seems like purge valve is leaking air and draining air out of tanks and airbags. Can leaking purge valve drain tanks/air system or theres check valves to prevent air leaking from the tanks/air bags?
    2013 Kenworth T660
  3. abyliks
    abyliks Road Train Member
    3,886
    9,083
    May 2, 2010
    ludlow MA
    What dryer do you have? I just went through a fcking nightmare on my w9 with an adsp on it, but that was also due to the Econ valve getting removed at some point in time
  4. mitmaks
    2,560
    2,075
    May 16, 2014
    It's bendix ad is
  5. abyliks
    3,886
    9,083
    May 2, 2010
    ludlow MA
    Start by Put a purge valve kit in it, I don’t think there’s a check valve on the IS, my sp has one before the wet tank but it’s extended purge
  6. mitmaks
    2,560
    2,075
    May 16, 2014
    So leaky purge valve won't drain tanks overnight?
  7. abyliks
    3,886
    9,083
    May 2, 2010
    ludlow MA
    It could. Start with replacing the purge valve
