Air governor cutting out every 2 minutes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jan 11, 2020.
  1. mitmaks
    mitmaks Road Train Member
    2,551
    2,070
    May 16, 2014
    As I'm driving down the road air gauges go down to 100psi and compressor kicks in and brings it up to 125psi and then it cuts out and purges air dryer. This keeps on repeating every 2-3 minutes.
    I don't hear air leak anywhere. What could cause this?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    An air leak.
    Could be in the pressure sense line from the tank to the governor.
    Could be the range cylinder on the transmission.
    Could be a brake pot.
    Could be ....
    spsauerland and mitmaks Thank this.
  4. mitmaks
    2,551
    2,070
    May 16, 2014
    Don't hear any leaks. Dropped it off at the shop they couldn't find an air leak either
  5. The Kraut
    The Kraut Medium Load Member
    597
    1,560
    Sep 5, 2013
    Land of Enchantment
    Air Dryer clogged! Had the same problem with a Cascadia years ago
    baha, intrepidor and mitmaks Thank this.
  6. mitmaks
    2,551
    2,070
    May 16, 2014
    I've replaced it past spring. Ill put another one on to see if it helps
  7. The Kraut
    597
    1,560
    Sep 5, 2013
    Land of Enchantment
    You can try to bypass it. At my Cascadia they took off the airlines and screwed them together. In and out was a perfect fit. So I made it to a shop that had a replacement. You can check it if it's really the air dryer before replacing it.
    mitmaks and baha Thank this.
  8. Powder Joints
    7,573
    7,556
    Sep 25, 2007
    Rosamond, SoCal
    Fix your air leak.
