Airtronic Bunk Heater
Discussion in 'Ask An Owner Operator' started by SuperDaveDenver, Feb 25, 2019.
  1. SuperDaveDenver
    SuperDaveDenver Bobtail Member
    22
    14
    Feb 14, 2017
    Denver, CO
    I have an airtronic bunk heater that was installed with my Tri pack APU. Unfortunately I got stupid a couple of days ago and I had let my fuel run down to about an 8th of a tank. My bunk heater hasn't started since then. I know I ran it out of fuel. What I am trying to find out is how do I prime the fuel line for the bunk eater? I have searched high and low on many forums and cannot find an answer. I know I ran it out of fuel. It was stupid but now I'm trying to solve the issue of how to prime it.
    Any help?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    I thought they were self priming, but it takes two or three start cycles for it to do it.
    86scotty Thanks this.
  4. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    I once watched a mechanic priming one, he pulled the fuel line off at the heater underneath the cab and had it cycle till fuel came out. Put it back on and heater was working.
    The fuel line in your tank might be a bit short for my liking. But that's the idea behind it, not to run a tank dry with the heater.
    Good luck and please report back.
  5. SuperDaveDenver
    22
    14
    Feb 14, 2017
    Denver, CO
    I thought they were self priming also. But apparently they are not. I let it run overnight to try and see if it would prime itself but it did not work.
  6. SuperDaveDenver
    22
    14
    Feb 14, 2017
    Denver, CO
    I guess that kind of makes sense that it won't pprime itself because of the air in the fuel line.... if it is still connected. By taking the line off at the bunk heater you're allowing the air to get pushed out by the fuel that is trying to be fed by the small fuel metering pump.
  7. tallmon
    tallmon Medium Load Member
    657
    320
    Oct 22, 2014
    Is it possible that it picked up some gunk from the tank bottom?
  8. SuperDaveDenver
    22
    14
    Feb 14, 2017
    Denver, CO
  9. SuperDaveDenver
    22
    14
    Feb 14, 2017
    Denver, CO
    That is also a possibility.
  10. mitmaks
    mitmaks Road Train Member
    2,563
    2,077
    May 16, 2014
    There should be inline filter just before pump
  11. Ridgeline
    22,439
    117,018
    Isn't there a filter some where for the heater, i bet it is plugged.
    But a bit of advice, never let your tanks go below 1/4 ever...
    KB3MMX Thanks this.
