Alley Dock
Discussion in 'Questions From New Drivers' started by D0618466, Mar 15, 2018.
  1. D0618466
    D0618466 Bobtail Member
    17
    4
    Mar 3, 2018
    Ok so I’m great when it comes to getting the trailer in the hole, and utilizing my formula to do so. Although my only problem is my set up. I was told it’s (from the first alley dock cone) you should walk out 10 steps and 41 steps across.
    I have the formula down pack, and can back in with no problems. During practice drills only because our set up cone is place when we practice the manuver, although when we take the actual exam no set up cone is there to help you as far as where you should pull up to. Anyone have advice on how far I should pull up so my approach is the right length away from alley dock cone, so once I start backing I’m in the right position for my formula to work ( hard right 1 DF away from the landing gear, straight back 5 ft, then a hard left turn 1 1/2 rotation on the steering rim).
    Need4Speed Thanks this.
  3. Moose1958
    Moose1958 Road Train Member
    15,133
    33,289
    Dec 17, 2010
    Williesburg, Virignia
    I might be a minority of one. You are going to find many of the times you are bumping a dock that there is either not a lot of room or some hazard blocking a standard setup. I highly recommend you not think so much about steps (the pivot point) and start working on sighting the trailer then getting out and looking. I'm saying this because I have seen yard dog drivers actually get out of their trucks and start cussing drivers for doing this. I'm aware that other posters are going to say screw these drivers. However when this happens it adds to your tension level and vastly increases your chances of making contact with another truck or a structure of some type. Go find a place off to yourself and practice these setups and maneuvers.
  4. D0618466
    17
    4
    Mar 3, 2018
    Ok trying to pass alley dock exam manuver, this is strictly for passing the manuver. I understand in the real world you have to go about things differently
  5. Moose1958
    15,133
    33,289
    Dec 17, 2010
    I had problems with this myself. That pivot point is very important. Go look at some youtube videos on this. A year after you get on the road and you look back at this post your going to laugh at yourself. I sometimes go back in my mind to my learning experiences and laugh at myself so much I almost lose my breath.
  6. Dave_in_AZ
    379,252
    My head just exploded like in scanners.
  7. Blackshack46
    Blackshack46 Road Train Member
    Sounds like they are setting you up for failure with all the cones to help you, but wont be there on test day. Its literally just trying to teach muscle memory, but that will not work come test day and you take 2 secomds too long to turn the wheel or lose the trailer, then you have to correct yourself with 1 or 2 pull ups without failing. Learn it the way you will do it in the real world, it will be a lot easier.
    My advice.
    Lose the cones, the formulas, the steps and actually learn how to alley dock. Its not hard. All your doing is steering the rear of the trailer by steering the trailers tandems.
    Wargames and Dave_in_AZ Thank this.
  8. Dave_in_AZ
    379,252
    My best advice is during your set up, assuming the hole is on your left, when your shoulder is even with the right side of the hole, crank wheel full right. When tractor is then strait with the hole ( don't worry about trailer ), crank wheel full left, until tractor is at 90 degree with the hole.
    This called 12 to 9. 12 O'clock to 9 O'clock.
    Your trailer back should be in almost perfect position now.
    Crank wheel full right, and start backing. You have to just start it moving, maybe 3 feet, then start cranking wheel to straiten out.
    When you set this up right, you could do it blind folded.
    Tigerstail and Blackshack46 Thank this.
  9. Moose1958
    15,133
    33,289
    Dec 17, 2010
    When it comes down to a state by state breakdown of what they require on the driving test I am not well versed. Because this school has the 45/alley dock i'm assuming it is required in that state. In the case of the driving test my best advice is to find out how this school is teaching how to determine the pivot point and go by that. Once you get with a trainer hopefully this trainer will help you start the process of mastering this backing maneuver. Honestly is not difficuit and once you do master it your good to go.
    OP maybe this short video will help you with this pivot point.
    Tigerstail and Just passing by Thank this.
  10. scottied67
    scottied67 Road Train Member
    10,818
    12,622
    Mar 14, 2010
    california norte
  11. Wargames
    Wargames Captain Crusty
    3,199
    7,360
    Jul 22, 2010
    WI.
    all that babbling, just back the truck up, a chimpanzee can do it.
