I have a 97 kenworth t800 with n14 celect plus . Usually my volt gauge will read around 14v when engine running. Recently it has dropped to 12v and will go below that if I turn on headlights. I was thinking of replacing alternator. The 400$ option is a 160 amp Delco . The 250$ option is a 170 amp alternator I forgot the brand it says it can’t be used with DIODE TYPE BATTERY ISOLATERS. Am I alright to use the lower cost alternator?
Alternator question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jleippi, Aug 15, 2024.
some starter/alternator shops will rebuild them for a ton cheaper than new one and be just as good, Davenport starter and alternator rebuilds them around here.Oxbow, Rideandrepair and The_vett Thank this.
I would confirm that the voltage at the B+ terminal on the alternator is low.
Other things can cause the same symptoms.Oxbow, Rideandrepair and BoxCarKidd Thank this. -
Yeah I thought I’d buy the cheaper alternator and rebuild the old one . That way I’d have a spare . But as far as the diode isolators ?? I don’t need to worry about that ?
How about do some troubleshooting first before loading up the parts cannon?
201, little cat 500 and beastr123 Thank this. -
I had a truck that did the same thing. It ended up being a loose connection on the alternator, (positive charging cable).
Yeah I hear you about the parts . But I was planning on keeping a spare alternator in the truck
Make sure all your cables are in good shape, and connections are clean and tight, does this first before throwing parts at it.
Walk into oreilly auto parts, they can get the right one with core return probably cheaper.
Think i walked out at 10 am next day (went in at 6 pm) for 170$ after core return on roughly same vintage truck about 2 or 3 months ago -
I’m up here in Canadistan
