Aluminum polishing and what to use on these tanks?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by W Bench Farms, Oct 21, 2023.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    Working on polishing some aluminum. I added some before and after pictures. Tanks are pretty rough, so will need some more work, but coming along. The one issue I'm having is getting rid of the black residue while I'm polishing. Using Zephyr polishing wheels and rouge. Have watched some videos and those guys make it look easy.
    blairandgretchen Thanks this.
  3. ducnut
    ducnut Road Train Member
    2,587
    7,805
    Dec 31, 2010
    SPI
    Most videos have them starting with a nicer surface.
    That tank needs sanded down, then, flashed with acid to clean the pores, before polishing. However, with the amount of sanding it’ll take, you may end up with a really thin tank.
    This is a piece where I removed casting flash and polished. You can see the progression, from left to right, and the final piece. Yes. That is a reflection of the sky.
    63AA28BD-392D-4F60-97BB-CCB890C018DD.jpeg 3CF444D9-D97D-4D5A-A67C-59B97590F5B6.jpeg
    A couple alloy bolts.
    Stainless tubing.
  4. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,183
    May 12, 2012
    SouthEast Alabama
    @ducnut That's some nice work you did.
  5. ducnut
    2,587
    7,805
    Dec 31, 2010
    SPI
    Thank you. I just piddle around.
    BennysPennys and 88 Alpha Thank this.
  6. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    Are you for hire!? Unbelievable work!
  7. Sons Hero
    Sons Hero Road Train Member
    2,698
    27,190
    Jan 8, 2021
    Indiana
    Do you have the tanks off? Tanks are much easier for me to polish on the floor than having to deal with straps and minimal room to work. Especially if they are really rough
    Last Call, ducnut and skallagrime Thank this.
  8. skallagrime
    skallagrime Road Train Member
    3,850
    9,923
    Apr 10, 2012
    Indiana
    Was just going to recomend that, and also you can see if its even worth polishing or straight up replace (or at least patch)
    ducnut and Sons Hero Thank this.
  9. Sons Hero
    2,698
    27,190
    Jan 8, 2021
    Indiana
    And, if you decide it will be to much work to get them mirror finished, Roadsknz has some mirror polished stainless tank wraps you can put on… not sure on price
    RoadSknz and ducnut Thank this.
  10. blairandgretchen
    13,576
    73,789
    Dec 9, 2011
    South west Missouri
    Times 2 on that. Well done.
    88 Alpha and ducnut Thank this.
  11. blairandgretchen
    13,576
    73,789
    Dec 9, 2011
    South west Missouri
    Looks like you'll need some sanding.
    To me - it's easier to pay a GOOD guy to sand and polish them the first time (and yours look rough) - then just maintain them.
    Kudos to you for giving a darn too - I always appreciate metal that is kept well, regardless of brand/color etc.
    Diesel Dave, bryan21384 and ducnut Thank this.
