Any law on when you have to do your pre trip?
Discussion in 'Trucking Industry Regulations' started by Bdog, Jan 19, 2016.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I have glanced over the regs but can't find anything stating specifically when you have to do it. Obviously before your trip but can it be hours before? Can you do it at the end of the day when your park the truck so you can roll first thing the next morning?
  3. SGIT
    SGIT Light Load Member
    246
    905
    Apr 6, 2015
    West Jordan, UT
    Wouldn't that be a post trip?
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    http://www.jjkeller.com/shop/Category/content____bi-inspections-maintenance-faqs___
    If someone pull your pin while you were sleeping, it will be still your fault if you drop your trailer for not doing a pretrip inspection.
    Do it once you're ready and start your log. The regs doesn't state how long it has to be, 1 min or 15 mins.
    TBonze and Snailexpress Thank this.
  5. snowwy
    snowwy Road Train Member
    20,567
    13,293
    Jul 6, 2009
    You can do your pre and post any time you want. There's no law on what time. Only that it has to be done.
    Course, if your smart and safe. You pre right before takeoff and post right after parking.Called common sense.
    A thorough pre is always a good idea. Cuz truckers like to vandalize or play games. Not often but it DOES happen.
    Last week. I watched 2 trailers that were sitting together. Both roll out of the truckstop. At different times. Both missing every light in the back.
  6. Bdog
    1,057
    877
    Nov 6, 2014
    Yes I always check things like the kingpin and a super quick walk around every time I drive after leaving the truck unattended.
    I was thinking more along the lines of if I wanted to do a more thorough pre trip checking all the fluids, belts, tires with a gauge, etc. if I could spend 30 minutes or so doing all that in the evening so that it is not eating into my 14 on the next day.
    Right or wrong I do a quick pre trip every day thumping tires, checking lights, kingpin, obvious leaks and then about every third day a do a lot more thorough job.
  7. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    You can but log it before you start your day not at the end of the night before. You should still check tires and lights. That crap leaks overnight and lights, well, you know.
  8. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    You could do it in the morning.....and do it in 5 mins instead of 30mins.....I mean you can show you did that in 5 mins, if you know what I mean
  9. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Then Wouldn't it be called a "Whenever the hell you wanna ~ Inspection"
    ?? Designated pre and post to eliminate confusion
    RustyBolt Thanks this.
  10. TBonze
    TBonze Light Load Member
    73
    55
    Sep 24, 2015
    Seattle, WA
    You have 14 work hours. Only so many can be for driving.... You have extra. I am not sure why you wouldn't want to be safe on the road every time regardless of the time it takes to do so.
    ANYTHING can happen overnight. And you only have one life. I would protect it if I were you.
  11. flood
    flood Road Train Member
    4,163
    4,035
    Dec 25, 2010
    yes you can BUT you must log the time as ONDUTY so why would you want to start your 14 hr. clock hours before you need too
    MrEd, RustyBolt and GreenMonster9669 Thank this.
