Any tips for pins that wont go in
Discussion in 'Intermodal Trucking Forum' started by 4noReason, Jun 8, 2016.
  1. 4noReason
    4noReason Road Train Member
    2,375
    731
    Nov 29, 2012
    Ok so sometimes ill find some good darn empties but the pin wont go in or lock. Because its not aligned. Do i need a lift or can i do something i only ask bcz if its loaded ill be screwed and have to find a flip and really i dont know how to do flips right now
    Dominick253 Thanks this.
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Depends what kind u talk on about. The back is easy to fix, the front, not so much. The twist kind or push kind?
    Dominick253 and 4noReason Thank this.
  4. 4noReason
    2,375
    731
    Nov 29, 2012
    Usually its the push kind. Today i had both. Wanted it nice chassis. But couldnt.
  5. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    If the box is sitting on the pin, you can grab your hammer and pound it back, u might need dw40. For the back, you can hammer the twist kind back to unlock. Be careful to not put your hand in the gap or the box will crush your hand once it drop.
    If the back pins are not align right to the box, you can find a rail track and bump it and it might jump in. Or you can move your tandem back and forward, just a hit it a little harder than usually.
    If the front is not align.... u can try to bump it on a track or curb.....or push it with another trailer if u know what I mean, the front is hard to fix if not align and I usually get help for that.
    But everything else u can fix it yourself
    4noReason Thanks this.
  6. 4noReason
    2,375
    731
    Nov 29, 2012
  7. RERM
    RERM Road Train Member
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    53, 40 or 20?
  8. RERM
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    53's flex quite a bit, sometimes moving the tandems will align the pins....
    Bean Jr. and 4noReason Thank this.
  9. 4noReason
    2,375
    731
    Nov 29, 2012
    I do 53's i rarely do 20/40 i assume its same
  10. RERM
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    Nope....53's flex more..... Sometimes if a front pin doesn't align, you can use your 5th wheel to push up the chassis corner and slide it in.
    Bean Jr., bowhunter67 and 4noReason Thank this.
  11. dumptruck89
    dumptruck89 Light Load Member
    79
    105
    Feb 27, 2015
    MA
    If it's a front pin and you are not hooked up yet, crank the landing gear down a ltitle bit. Then back in at an angle with the 5th wheel on the side pin won't go in that should twist the chassis enough to slide it in. Also if you don't have full fenders on your truck like I do, keep a 4x4 with you and if the front pin won't line up because the box is to low or the pin is stuck, put the 4x4 on your drive tire and drop the suspension it should twist the container just enough to get the pin in or out.
    RERM and 4noReason Thank this.
