Anyone have an Esbar bunk heater?
Discussion in 'Experienced Truckers' Advice' started by TruckRunner, Oct 20, 2018.
  1. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    My truck came with one and I don't really like it. Do you have to set the temp really high for it to stay on? It runs for a little while then cuts off and gets cold in my sleeper again. I don't know what type of system the company I drove for had but it remained on until you turned it off and it could blow fire all night.
  3. Cattleman84
    Cattleman84 Road Train Member
    9,925
    70,822
    Nov 1, 2017
    The Sticks, Idaho
    Sounds like the computer is cutting off the power to the heater (and probably other auxiliary circuits) because the heater drains the batteries to a point that is considered minimal in order to start truck... Weak batteries is one of several reasons this can happen. Do 12 volt outlets, CB radio, internal lights amd other auxiliary electronics also quit working about the same time??
    mhyn Thanks this.
  4. TruckRunner
    704
    3,270
    Dec 21, 2017
    No I still have plenty of power and a readout of my current voltage. I am thinking I have to set it at a high temp so it remains on. If I hit the off button and turn it back on it turns back on in five minutes and stays on for a while until it eventually cuts off again. I remember the salesman telling me it will turn off once it reaches the temp I set it at. Though when it cuts off it gets cold again.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    yes turn it on high and fall alseep. 3 hours later and you will be butt naked standing in the cold snow
    86scotty, TruckRunner and D.Tibbitt Thank this.
  7. supersnackbar
    19,186
    47,558
    Aug 19, 2007
    Your Town, USA
    It needs serviced. At least once a year they need opened up and a new glow plug installed and the flame screen cleaned. You can try running it wide open for 10-15 min if it'll stay running, sometimes that will clear it out enough to run for a week, but it needs a yearly DNC (dusting -n- cleaning)
  8. TruckRunner
    704
    3,270
    Dec 21, 2017
    OK I think I solved my own problem. I set it to a high temp and it hasn't turned off since.
  9. Brandt
    Brandt Road Train Member
    4,508
    6,174
    Sep 17, 2012
    They also work best below 45f. They don't like Turing on and off completely. When it's 45 or colder it can run on low heat but keep going all night long as it get colder it will turn up the fan and heat as needed.
    Hegemeister and TruckRunner Thank this.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Some controllers heat it up the first time. Then it rests, measuring the temperature drop over a period of time. Then it will restart and run at a speed that will maintain the set temperature.
    Also it could be that the controller is either too close to an outside wall, or too close to the output of the heater.
    If yours only has the rotary dial , the actual temperature sensor is down in the intake of the heater.
    mhyn and TruckRunner Thank this.
  11. TruckRunner
    704
    3,270
    Dec 21, 2017
    Yeah when it first came on the fan was so loud I thought my truck was about to explode. Mine is the digital control not rotary.
    uncleal13 Thanks this.
