Anyone know 13 speeds Eatons really well?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6cuda6, Dec 28, 2020.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    I have an oddity....Eaton 13 speed manual....upshifts and downshifts fine except downshifting from high to low in 8th or 13 to 12.....seems to grind or not make the shift when you let off and reapply throttle...upshifts fine. IF you downshift from high to low in any other gear it's fine just not 8th or 13th.
    Ideas and insite?
  3. AModelCat
    159,363
    Came to see what a 12 speed Eaton is lol.
    Just on the downshift? Is the splitter acting lazy?
  4. Super_Trucker
    Super_Trucker Bobtail Member
    30
    89
    Feb 6, 2020
    Central Texas
    Haha me too
  5. 6cuda6
    259
    176
    Oct 9, 2020
    Yup....working like a 12 speed ...lol.
    Yah downshift from 13 to 12 only....seems lazy but i have nothing to compare it to.....all other gears seem fine though even if it is lazy. It kinda "hangs there" mid shift and if you put it back into high it goes back, doesnt like it of course but it does [if this was a car i'd say the shift fork was worn out on that side but it's not like that i beleive?]
  6. 6cuda6
    259
    176
    Oct 9, 2020
    As above.....lol.
  7. blairandgretchen
    13,379
    71,941
    Dec 9, 2011
    South west Missouri
    Well, I’m intrigued.
    I had mine redone - and watched the guy do it. He’s well experienced with them.
    Mine, on the odd occasions, when splitting up from 12 to 13, doesn’t want to go. Just hangs in limbo, and free revs.
    jamespmack Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    I would re- oring the splitter cylinder. Sometimes they get logged with oil or just plain dry orings. Coat the rings good with the supplied Eaton grease ....its good stuff. The kits cheap and its a 30 min job if youve done it before.
  9. 6cuda6
    259
    176
    Oct 9, 2020
    Sounds like a plan....nothing to loose and all to gain.
    blairandgretchen, Coffey and Goodysnap Thank this.
  10. jamespmack
    215,830
    Make sure all exhaust ports are clean, and filter regulator is clean on transmission before you do anything. If your in cold climate like half of us are this time of year, when was the last time you changed you truck air dryer? Or drained your air tanks. Small air lines always freeze first.
    All of eatons books are free online. Just need model number. They have decent flow charts.
    blairandgretchen, Goodysnap and 6cuda6 Thank this.
  11. 6cuda6
    259
    176
    Oct 9, 2020
    Air dryer desicant changed, dryer cleaned out.....tanks drained regularly.
    Will check filter/reg as dryer can was pretty nasty (new to me truck)
    blairandgretchen and jamespmack Thank this.
