Apu tri pac not blowing cold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Apr 9, 2020.
  1. mitmaks
    mitmaks Road Train Member
    2,579
    2,093
    May 16, 2014
    My apu a.c. not working properly. It starts up and I hear it run but it just blows warm air.
    Probably refrigerant leaked out. I looked in manual and it says 1.2-2 lbs needed depending on size of hoses.
    Any things I could check to make sure it's not something else?
    truckdriver31 Thanks this.
  3. 062
    062 Road Train Member
    6,285
    33,806
    Oct 20, 2013
    Make sure the condenser fan is working. You can pick up a can of 134 that has the gauge, and hose to see if it has any Freon in the system. If it’s a small leak there may be enough to charge it back up temporarily.
  4. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    put gauges on it first. dont buy or fix anything until gauges go on it
    mitmaks and BoxCarKidd Thank this.
