Aren't we supposed to dump the air bags before we slide the 5th wheel?
Discussion in 'Experienced Truckers' Advice' started by expedite_it, Jan 30, 2022.
  1. expedite_it
    expedite_it Road Train Member
    1,646
    863
    Sep 8, 2012
    About a year ago, I was having trouble sliding my 5th wheel. I called breakdown because I thought I would need a mobile mechanic to come out and repair my 5th wheel. Breakdown wanted to walk me through the process of sliding the 5th wheel before they sent out a mobile mechanic. I always extended my landing gear to the ground when i would slide the 5th wheel, but after I told breakdown that the feet of the landing gear were on the ground, breakdown instructed me to keep extending the landing gear until I heard the air rush out of the air bags. So I continued extending the landing gear until I heard the air rush out of the air bags. Then I tried to slide the 5th wheel, and, lo and behold, it worked. The 5th wheel slid gently, and I was able to get the pins of the 5th wheel to line up exactly where I wanted them.
    Previously, whenever I slid the 5th wheel, I did not dump the air out of the air bags, and sliding the 5th wheel was a very violent process. It was very difficult to slide the 5th wheel anywhere except all the way forward or all the way back. If I needed to slide the 5th wheel to somewhere in the middle, it would take me a long time, frequently over 30 minutes.
    This made me a big believer in dumping the air out of the air bags when right before I slid the 5th wheel. Breakdown told me that there are two ways to dump the air out of the air bags: 1# extending the landing gear of the trailer until I heard the air rush out of the air bags or 2# pressing the "SUSP DUMP" button inside the cab of my tractor.
    I recently bought the Delmar's Tractor-Trailer Truck Driver Training book. The book gives instructions on how to slide the 5th wheel on two pages. Neither set of instructions mentions anything about dumping the air out of the air bags before sliding the 5th wheel.
    Here are photographs of the cover of the book and the pages of the book that give instructions on how to slide the 5th wheel:
    Why didn't Delmar's Tractor-Trailer Truck Driver Training book instruct its readers to dump the air out of the air bags before sliding the 5th wheel?
    fairshake and Chinatown Thank this.
  3. Dave1837
    Dave1837 Road Train Member
    1,399
    4,343
    Nov 16, 2019
    Pennsylvania
    Not sure why the manual doesn't say so, but the proper way to slide a 5th wheel with a loaded trailer attached is to have zero load on the 5th wheel. I've always done it by lowering the landing gears to the ground and dumping the air bags, like you stated. However, if it's a heavy load it may not work. The best way for me to think of it is as a semi auto handgun. If there's extreme force on the slide, it won't cycle properly, or at all. If there's weight pushing down and you try to pull back or push forward, it will bind and jam. The goal is to take 100% of the load off of the 5th wheel so it slides freely. I hope this helps
  4. expedite_it
    1,646
    863
    Sep 8, 2012
    Just out of curiosity, why wouldn't dumping the air out of the air bags help if it's a heavy load? Is it because if it's a heavy load, the weight of the trailer might be pushing down with so much force that dumping the air out of the air bags won't make it so there is zero load on the 5th wheel?
    The fact that the authors of Delmar's Tractor-Trailer Truck Driving Training book didn't say to dump the air out of the air bags right before sliding the 5th wheel has made this book lose a lot of credibility in my eyes, unless someone here can give a good reason why dumping the air out of the air bags should not be mentioned in the instructions for how to slide the 5th wheel.
    Furthermore, look at the first instruction: "Be sure to set the trailer parking brake before getting out of the cab--for any reason. This will prevent the tractor from rolling."----WHat?! Shouldn't that say be sure to set the TRACTOR parking brake, not the trailer parking brake?
    I feel like maybe I should throw this book in the trash can.
  5. expedite_it
    1,646
    863
    Sep 8, 2012
    The first instruction says "Be sure to set the trailer parking brake before getting out of the cab---for any reason. This will prevent the tractor from rolling."
    The author must have meant the parking brake, but the first word of her description of the brake was trailer. The red brake valve is for the spring brakes on the trailer. People will associate any brake valve that says trailer on it with the red valve. The red valve even says "Not for parking" on it. Trailer brake.jpg
  6. AModelCat
    158,913
    They probably mean set your trailer brakes because if the fifth wheel lock didn't lock, the trailer could roll and push the 5th wheel to the end of its slide.
    God prefers Diesels Thanks this.
  7. expedite_it
    1,646
    863
    Sep 8, 2012
    No. It said to set the trailer brakes so the tractor wouldn't roll, not so the trailer doesn't roll. The author didn't say what you're saying.
  8. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    I lower the landing to about an inch off the ground so the fifth wheel is not hanging on the pin and dump the air bags. Works fine for me.
    Don't ever get out of the truck without setting the break.
  9. Siinman
    Siinman Road Train Member
    5,283
    13,360
    Mar 5, 2017
    Kansas City, MO.
    Sounds like a dumb book to be using. Kind of common sense to drop bags so it takes the pressure off of slide.
  10. expedite_it
    1,646
    863
    Sep 8, 2012
    The book never even explicitly says to lower the landing gear to the ground in the first place. If you drop the air bags without the landing gear down, it won't take the pressure off the 5th wheel.
    The book spells out everything else about the process instead of just letting it go without saying because it's common sense. So why not mention dumping the air bags?
  11. expedite_it
    1,646
    863
    Sep 8, 2012
    What do you mean when you say you lower the landing gear to an inch off the ground so the fifth wheel is not hanging on the pin?
