Automatic Transmission VS Stick
Discussion in 'Swift' started by ronvicki6653, Nov 15, 2016.
  1. ronvicki6653
    ronvicki6653 Bobtail Member
    26
    11
    Sep 2, 2009
    Las Vegas, NV
    I started with a stick with Swift in 1996. Back then we had to fuel only at the yards. We did allot of doubles as company driver. We had low profile trucks to haul the 14 foot trailers. The 14series trailers had big stickers on nose letting you know couldn't go east of Mississippi River & AR. Trucks didn't have ABS brakes, didn't have traction control. In the winter you would see many trucks wrecked in the medium. There was no 14hr rule, which I think is dangerous. It makes you rush. You use to be able to split sleeper anyway you wanted. If you got tired, you pulled over and slept. Stick transmission, you the driver, are in total control. Awwsome in winter driving on snow packed roads & ice.
    First truck with automatic transmision this year. Been driving it approx. 5 months now. Don't like it. From a stop, trying to turn left or right on busy street. Approx. 3 second lag from pedal till movement, not good. Upshift should be at approx. 15000 RPM. Downshift should be at approx. 11-12000 RPM. Normal operation. It up shifts lugging the engine, jumping 2 gears most of the time. Downshifting(Auto) is the dangerous and scary part for Winter driving. It downshifts multiple gears, overreving engine, witch will be dangerous on snow packed icy roads. New drivers be vary careful in winter driving with Automatic trannys. The manual switch, has limited power when switch on. It's good down grade with jakebrake. Don't forget to switch jakebrake to lower setting when going back to auto. Please, comments from other experienced drivers with stick to automatic transmisions. I don't like them and I think they will be dangerous for winter driving.
  3. gnaunited
    gnaunited Light Load Member
    66
    73
    Jun 7, 2013
    Denver, CO
    I have experience driving Volvos with the ishift + D13 engine. 99% of your control is still centered around your right foot, not your left. Learn the transmission and how it works.
    I should also mention that the ones we get only have the economy mode, so skip shifting is all it knows. The one thing I have learned it to feel when it is done letting out the clutch because once it does, then it will apply whatever power you told it too. When I first started driving them, starting out empty was hard as it is smoothly lets out the clutch, and then ramps up to whatever the accelerator is pushed to, meaning you might take off a lot faster than you thought.
    MidWest_MacDaddy Thanks this.
  4. FLCRACKER
    FLCRACKER Medium Load Member
    344
    203
    Oct 11, 2013
    Lorida, FL
    The 14 hr rule is dangerous. I drove back then could take a 4 or 5 hr break would affect hours for the day.
  5. FLCRACKER
    344
    203
    Oct 11, 2013
    Lorida, FL
    Aggreeing with you misread it the first time.
  6. MidWest_MacDaddy
    11,151
    18,751
    Feb 21, 2015
    South Carolina
    Ok, one vote against... {shrug}
  7. MACK E-6
    48,719
    224,889
    Make that two...
  8. MidWest_MacDaddy
    11,151
    18,751
    Feb 21, 2015
    South Carolina
    Ok, two votes against... {shrug}
  9. scottied67
    scottied67 Road Train Member
    10,818
    12,622
    Mar 14, 2010
    california norte
    If I hire drivers to run my trucks I'm all over the AMT transmission for them. Driving with a manual takes the next 14 levels of concentration, professionalism, the proper mentality, patience, skill, mellow personality that today's trucker doesn't seem to possess.
    I blame our society on that, today's truckers are more and more subconciously aware that life is short so they need to race around and max produce dollars in a short of time as possible at the expense of proper and legal shifting techniques. The 14 hour clock ticking down down down has a negative affect on the driver as well. Before the 30 minute break requirement, you at least could see your full 11 hour clock available on the qualcomm and if you stopped and had a healthy portion of your 14 still avaiable, the remaining 11 hours clock would not tick down.
    Enter the age of the requred 30 minute *rest* break and soon as you start your 14 hour clock you see an 8 hour clock immediately, incessantly and aggressively ticking down-- 7:59, 7:58 -- and so on. The pressure just increased by a factor of 10 on the driver. Plus you have these safety manager types advising when the optimal time to take that 30 minute *rest* period so as to limit it to once per 14 hour period--- how is that restful when the driver cannot pull over when (s)he wants to. "...only 3 more hours and I can pull over for 30 minutes ***Yawn, eyeballs heavy and drooping....***
    Young buck truck drivers have all this stress todeal with and are ripping off hoods and bumpers because they are trying to look at the stick shift instead of their mirrors, so yes companies are going to the AMT because they don't want to invest the extra time in training these new drivers in proper shifting techniques and proper space management. Cheaper to put these new drivers out on the road pulling freight bringing revenue into the company. They crash out? Just fire the driver and sully their DAC report.
    ronvicki6653 Thanks this.
  10. Old_n_gray
    Old_n_gray Road Train Member
    1,190
    4,011
    Apr 9, 2016
    western pa
    One vote for....I like them. 12 speed mack with a window in the back!!!!! Bull frog in color.
    MidWest_MacDaddy and scottied67 Thank this.
  11. SteveH85396
    SteveH85396 Road Train Member
    1,646
    810
    Apr 1, 2011
    Waddell, AZ
    I've been driving an AMT for the past 5 months and DO NOT LIKE IT! That said it is great when I'm stuck in traffic (every other day in SoCal) and SUCKS the rest of the time.
    My issues: It's an Eaton 10-speed in back of a Cummins ISX15. The transmission never shifts the same 2 days in a row. It almost NEVER tries to use the engine's low-end torque instead keeping it up around 14-1700 rpm, unless it's at speed in 10th gear. Some days it will pull down to 1200 rpm in 9th (nice climbing pace when light) but most of the time downshifts to 8th @ about 1300 rpm which slows the truck 3-5 mph and totally ruins any drive you have going uphill. I HATE how slow the truck is bobtail as the computer is limiting engine output until it get to highway speeds. My DD-15 powered Cascadia (with a 9-speed manual) was seriously QUICK once you got it in the high side of trans, this thing is a slug! Moving the truck a few inches (daily at the ports) and hooking to a trailer/chassis are a real pain as you have almost no control over clutch engagement.
