Automatic Truck loses transmission air
Discussion in 'Questions From New Drivers' started by Schöne, Feb 28, 2024.
  1. Schöne
    Schöne Bobtail Member
    47
    20
    Feb 23, 2019
    I'm not a new driver but I'm new to driving automatic trucks. I've driven both KWs and Peterbilts and they both lose transmission air when backing up and you have to wait for air to build up if you shift too many times. This is especially frustrating when backing in tight spaces where you have to reposition several times. Is there a trick to it? I've heard of not using the brakes too much etc....but it doesn't seem to help.
  3. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    952
    1,845
    Dec 15, 2021
    Might be easier backing in R1,if it's going into R2 when reversing.
    Bean Jr. Thanks this.
  4. Brandt
    Brandt Road Train Member
    4,605
    6,326
    Sep 17, 2012
    Freightliners have Hill Start Assist. When backing if you push brake pedal it will come on and hold truck then dump the air when you move. You could try turning it off if you have that button on dash. Just make sure you don’t roll. Flat parking lots you don’t need it and it seems to use more air
  5. MACK E-6
    49,730
    234,953
    Welcome to the new way, which everybody knows is so much better than the old “manual” way.
    Hatt91, Bean Jr., Bud A. and 5 others Thank this.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,833
    18,725
    Nov 1, 2010
    Burnsville, MN
    I have used both Freightliners and Internationals with auto and neither had that problem.
  7. Blagoje
    Blagoje Medium Load Member
    441
    960
    Jul 14, 2022
    Paris, Illinois
    I have a late model Kenworth with the 12-speed automatic transmission and this is an inherent problem from what I've been told. This transmission uses a lot of air to shift gears and that is just the way it is. Mine regularly runs out of air when I am backing up and sometimes when driving forward.
  8. TurkeyCreekJackJohnson
    TurkeyCreekJackJohnson Medium Load Member
    457
    1,251
    Feb 7, 2024
    South Western US
    I drove an '18 Volvo 670 that was the same way. Compared to other automated manuals I've driven, it seemed to hold the brakes much longer than necessary. Lots of rough movements until I learned the trick you referred to.
    77fib77 and Brandt Thank this.
  9. aramil248
    aramil248 Road Train Member
    1,343
    1,311
    Jan 16, 2017
    Maine
    International having a separate air tank for it I heard. With no gauge to see it's level. I swear the last one I drove. Run out just pulling up after fueling
  10. Bud A.
    Bud A. Road Train Member
    2,637
    16,742
    May 10, 2015
    Mountain Time
    I got put in a truck with a manual after two years of automatics. It's so nice to just use the clutch to bump docks.
  11. Schöne
    47
    20
    Feb 23, 2019
    Same trick applies to KW?
