Axle Weights for Single Axle hauling doubles?
Discussion in 'Questions From New Drivers' started by FreightlinerGuy, Apr 23, 2014.
  1. FreightlinerGuy
    FreightlinerGuy Medium Load Member
    472
    225
    Apr 20, 2008
    Great Lakes, USA
    Hey all,
    I'm needing help seeing what the axle weights and such should be for a single axle hauling doubles.
    If I am understanding correctly each trailer can have 24k loaded into it. What should each axle weigh to get me at or below 80k?
    Thank you
  3. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    I'd say 17000. 17000*4= 68000 + 12000 for steers = 80000. But I don't pull doubles.
    FreightlinerGuy Thanks this.
  4. blairandgretchen
    13,376
    71,900
    Dec 9, 2011
    South west Missouri
    We are normally 11,700 on steers, 19 on single screw drives, the other 49,300 spread over the remaining 4 axles.
    No more than 20 k on a single axle. Most states let 200lbs or so fly.
    FreightlinerGuy and double yellow Thank this.
  5. blairandgretchen
    13,376
    71,900
    Dec 9, 2011
    South west Missouri
    2 24 k trailers will be pushing it, a 24 and a 20 is often grossing us out in a 2014 Cascadeeeeearrrrrr.
    Depends on the accuracy of your bills.
  6. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    Here goes, and I pull doubles and have for the last 20 years.
    Your allowed 12,000 to 12500 depending on the rating of the tires and axle.
    Your allowed 20,000 per axle 40,000 per trailer.
    you are still governed by the 80,000 gross. You do not get 92,500 without a overweight permit.
    So if your legal you will probably not ne more than around 16,500 or so on the drives and trailer axles.
  7. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    Bills are never accurate enough.
    KF7WTV and blairandgretchen Thank this.
  8. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    Start over.
    First off my earlier post has the legal max listed. The first thing you have to do is hook up to them empty, fuel your tractor and go axle them out. list it like this Steer, drive, or drives, axle 3, axle 4 and axle 5.
    First subtract your tare total weight from 80,000.
    Take the difference and divide it in half, you should try to balance the load between the trailers, making sure if one is heavier it goes in front.
    Normally 5th wheels are set directly over the drives with double. Your steer weight should not change when loaded, the drives carry the weight.
    Hope this helps.
  9. mattbnr
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    So basically what I said.
  10. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    Yeah, but with out the tare you don't know how to load the trailers.
  11. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    The one measurement that most seem to forget about is from the center of the axle on the first trailer to the center of the axle on the dolly. If they are less than 10' apart, you CANNOT put 20k per axle in most states. This is the one that catches drivers with over weight axles.
