Backing up doubles
Discussion in 'Experienced Truckers' Advice' started by Air Cooled, Jul 1, 2016.
  1. Air Cooled
    Air Cooled Road Train Member
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    id like to revive this old topic I came across. Obviously, I'm able to back up a semi trailer and for the last 4 years, I've mastered the west coast truck and trailer setup. I'm with a new company and we have double tankers, double pneumatics, and double bottom dumps. It's my first time pulling doubles. I can back them about 20 feet before I lose them. I had a hard time learning the truck and trailer setup until I figured out it was opposite a semi and needed small movements. The videos I've watched on YouTube have the tractor making very large turns and movements to keep the rear axle first trailer in line with the dolly (or turntable in my case-they are fixed). I don't really need to know how to do this because we don't really go anywhere that it's necessary BUT... Street cred and tricks are always fun. GasHauler can you chime in??
  3. MACK E-6
    49,718
    234,760
    Well, since you mentioned @GasHauler, he deals with the "truck-full trailer" combo IIRC.
    That's a bit of a different animal than the more familiar "tractor-semi trailer-full trailer" combo that the LTL carriers all use. I heard stories of drivers backing this successfully, but I've never seen it done for more than a truck length before everything starts pointing different directions.
    Dominick253 Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    There are a couple of truckers I have witnessed who can do this. But those #### doubles will begin to point wrong not too far into the backing if your steering is so much as a inch off. Hell, the slop in the steering box is enough to throw off such precision backing.
    Consider this a stunt. If you master it then I will prostrate before you after you do the 4 barrels backwards with a set of doubles. Im not talking about the B train 5th wheels, Im talking about the little ring hooks that hitch.
    I used to run a beaver on such a ring hook and backed it fine. But would not want to back TWO trailers that I now have seen on some RV's towing a Car and then a boat attached to that car.
    Dominick253 and Naptown Thank this.
  5. blairandgretchen
    13,656
    74,242
    Dec 9, 2011
    South west Missouri
    Back the dolly at the end of the first trailer up to the rear trailer - yes. Distance of less than 50'.
    Back the whole set - maybe 30' before Jack the Knife appeared.
    And that was after 8 years of fooling with the things.
  6. BigPerm
    BigPerm Medium Load Member
    Used to deliver pneumatic sugar to Kraft in L.A. You had to make a u-turn & back up to the building to unload. Everything had to be perfectly straight for the hoses to reach.
    Me = 20 minutes, hot, sweaty.
    Normal route driver = 5 minutes.
    Whew.
  7. Naptown
    Naptown Road Train Member
    1,156
    2,983
    Oct 18, 2009
    Indiana
    I've been working hard at learning how to set up and back a dolly underneath the rear trailer. It has made my life a little easier more than once, especially in places like our Paducah, Ky barn which is all dirt, gravel, and potholes. It is also handy when I simply feel like being a little lazy (which is most of the time).
    I've seen a handful of guys that can back a full set without jacking it all over the place. They're kind of like vegans in that they will tell you about it whether you ask or not. It takes a lot of room to set up right, and given that most places are packed pretty tight there isn't much use for it. The few times I've seen it done the general opinion among the onlookers was annoyance rather than awe because the backer was blocking people from getting through.
    Toomanybikes and Dominick253 Thank this.
  8. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    I pulled them for 8 years myself with a 379 Pete. I tried a couple of times to back them but found out quickly, its more time and effort than its worth and that was just straight line backing.
    Ive heard there are guys who can do it, but never seen them myself. There was a Con-Way driver won the Truck Championship at the truck rodeo one year with doubles. He was about the best I ever saw at backing them but he didnt back them too far before they started jacking on him.
    Just a slight slant in the terrain you are backing on can throw them off. Its fun to try sometimes but Id never get disgusted if you cant because I dont believe it will ever be anything thats required of you. Learning to operate them safely in all kinds of weather and conditions will be a much more rewarding goal and one you will be judged on more.
  9. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    One of these days, I'd like to try backing up doubles. I used to run super-b and had a couple guys, whom were drivers, stare in amazement when I backed a set into a parking space at the Flying J in Billings.
    And this was at night between two already parked rigs.
    "How do you do that?!?"
    "Practice!"
    roadranger550, x1Heavy and HighCountry Thank this.
  10. Trubb43
    Trubb43 Light Load Member
    185
    67
    Mar 16, 2014
    For me it seems easier to blind side 20's don't know why
  11. Dominick253
    Dominick253 Heavy Load Member
    746
    634
    Nov 19, 2015
    Like this.
    Upright, rank, Skate-Board and 4 others Thank this.
